Tractor Talk Discussion Forum
706 still not running
Cory A.
02-21-2005 15:04:18
I put a post up not to long ago about our 706 and got a lot of help but it's still not running. It is getting a spark and we got it to pop but it won't start. We also tried some starting fluid and about blew everything up. Any help would be appreciated! Thanks!!
JDknut
02-22-2005 14:37:25
 Re: 706 still not running in reply to Cory A., 02-21-2005 15:04:18
You might want to check the timing. I saw a Ford pickup with a 302 do that once, pop during an attempted start and what it did was jump time. Drove us knuts trying to figure it out as we did everything to it but paint it green to get it to start. Had to throw in a new cam and chain to get it to start. The timing chain was rotten enough so that a good jolt during an attempted ether start (it was 20 below at the time) was enough to get it to jump time so it would not start. I dont know if your engine has a timing chain but if it does that might be the problem. The distributor might have jumped, too. I don't use ether in anything I care about, either. I have seen too much of what it can do. Plug it in to warm it up and keep it in good tune and you don't need ether. Just my $0.02.
xxdonxx
02-21-2005 19:27:33
RAB you don't know much about 706's do you. they have a hydralic clutch.
RAB
02-22-2005 09:17:48
 Re: 706 still not running in reply to xxdonxx, 02-21-2005 19:27:33
Thanx for the info 66.168.173.6. My post was still a lot more useful than yours. Mine was at least a reply for the thread.
caseyc
02-21-2005 18:15:44
i missed the last post. where are you located? did you buy the tractor not running or did you rebuild it and can't get it started?
casey in SD
Cory A.
02-22-2005 13:47:22
 Re: 706 still not running in reply to caseyc, 02-21-2005 18:15:44
Hi I'm in Nebraska and it was running when we bought it but it just stopped running one day. we replaced just about every electrical part on the thing. I don't know if its not getting gas or there is a problem with valves but I appreciate all the help.
the tractor vet
02-21-2005 16:54:28
Well i could tell ya to just bring it over and if i could not make it run then we would just shoot it and plant it .
Cory A.
02-22-2005 13:55:46
 Re: 706 still not running in reply to the tractor vet, 02-21-2005 16:54:28
That sounds like a last resort, but if we can't get it running it will be parts for another one.
Weirsdale George
02-21-2005 15:08:20
Cory A. wrote, "We also tried some starting fluid and about blew everything up."
What do you mean by this? At first guess it sounds like your timing is way off.
Cory A.
02-22-2005 13:53:35
 Re: 706 still not running in reply to Weirsdale George, 02-21-2005 15:08:20
Well we were messing with the timing when this happened. There was just a little too much starting fluid and we pushed the timing the wrong way. It was really loud and flames were shooting out.
RAB
02-21-2005 15:25:19
Or.... a valve open when it shouldn"t be, or plug leads on wrong plugs (yeah - way off timing!), or dist cap cracked, or just too much fluid.
Perhaps needs a tow start?
Regards, RAB
