Tractor Talk Discussion Forum
660 D
706
02-21-2005 15:20:49
COULD ANY BODY TELL ME ANY GOOD POINTS OR BAD ABOUT THE 660D I JUST BOUGHT ONE THANKS.
JDB
02-22-2005 10:42:58
 Re: 660 D in reply to 706, 02-21-2005 15:20:49
Good tractor. Glow plugs can be a pain but a good puller and hard worker. Not bad on fuel. Grew up on a wheatland 660. Needed an extra 40 acres just to turn it around.
ih650
02-21-2005 17:00:42
I have had a half a dozen 660's. They start hard but pull real well. Like all IH tractors they have weak T/A's. The RPM's run at 2650 with no load. They turn alot of heads. Not many made.
Hugh MacKay
02-22-2005 05:01:45
 Re: 660 D in reply to ih650, 02-21-2005 17:00:42
TA was not weak, the weakness occured in operator above the ears.
paul
02-21-2005 16:00:54
How many hp is it anyhow? Would help to answer your plow question below. I need all of 20 hp per 16 inch bottom, 25 or more hp for an 18 inch bottom. I have real heavy clay soils.
Also, good to mention the manufaturer too - lots of different manufaturers used the same numbers at different times.
And, sometimes all-caps is really hard to read - might consider taking that caps-lock key 'off' and not look quite so harsh. :)
--->Paul
706
02-21-2005 16:38:49
 Re: 660 D in reply to paul, 02-21-2005 16:00:54
82 pto horsepower i would say 14 to 16 inch plow the ground is half and half. thanks
paul
02-21-2005 20:20:05
 Re: 660 D in reply to 706, 02-21-2005 16:38:49
That's a little bigger than I was expecting it to be! :) Here in my soils I would put a 4-16 behind it. Lots of other places they would try a 5-16 on it I hear. :)
--->Paul
