Tractor Talk Discussion Forum
JD60 manifold glows
mikrot
02-23-2005 14:05:58
I've got a JD60 and after running it for about 20 minutes the manifold and muffler pipe are glowing hot. The muffler is not plugged. But sometimes it acts like it is underpower and sometimes likes to backfire. any help
37 chief
02-23-2005 19:49:29
 Re: JD60 manifold glows in reply to mikrot, 02-23-2005 14:05:58
I can still remember my dads F 12 exhaust manifold glowing red. This would show up at night. He would cut beans at night to keep the beans from shelling out, due to the heat of the day. To see the manifold glowing during the day may be a problem. Would a lean mixture cause this? Stan
Jerry/MT
02-23-2005 19:11:47
Like the other guys said, check your initial igbition timing and distributor advance and make sure that your mixture isn't too lean (carb adjustment or leaky induction system downstream of the carburetor). You can burn exhaust valves up running like this
Mike Aylward
02-23-2005 18:31:20
Mikrot, my guess is that you or someone before has had the governor off of your tractor and mis-timed it. Your tractor has the classic symptoms of someone lining up the timing marks from the camshaft with the ones on the governor. If the flywheel is correctly installed and the slots in the flywheel are horizontal the distributor drive slots will be horizontal as well. And the "V" mark on the governor drive gear will either be straight up or straight down (either way will work). DO NOT line up the governor "V" mark with the camshaft mark. Mike
farmweld
02-23-2005 14:51:14
sounds to me like a timing problem. if not that then runnin too lean.
farmweld
paul
02-23-2005 14:12:59
Timing? Too lean?
I assume this is under no real load, just running?
--->Paul
Jon H
02-23-2005 15:34:40
 Re: JD60 manifold glows in reply to paul, 02-23-2005 14:12:59
Agree with the others. Red hot exhaust system us usually very retarded timing or stuck advance weights in the distributor not allowing any spark advance at speed. check timing and advance with a timing light. Spark should advance smoothly from the initial setting as rpm increases.
