Tractor Talk Discussion Forum
Single hydraulic on double valve?
Kevin T.
02-23-2005 20:14:56
Just bought a used Mo-Co that has a single-acting hydraulic cylinder to set the cutting height. Return is by spring. My IH has a remote for double-acting cylinders (4 way valve with 2 outlets). Can I safely connect the mower to just one side of the tractor's hydraulic valve? Any better way to do it that doesn't cost an arm and a leg?
Nebraska Cowman
02-24-2005 03:30:37
 Re: Single hydraulic on double valve? in reply to Kevin T., 02-23-2005 20:14:56
i do it all the time. you might find it works better on one side than the other.
Van in AR
02-23-2005 20:25:48
Most IH tractors I have seen have a selector on the hyraulic control to be able to use a single acting cylinder, may have to pull the hood to find it, should be on top of the spool unit that your levers attach to.
Van
