Tractor Talk Discussion Forum
Shifting Problem
R.C.C.
02-24-2005 12:45:38
I have Massey Fergson 35 ,just finished rebuilding it every thing worked fine. After sitting 5 weeks you couldn't move the shifting leaves out of geer.
Willy-N
02-24-2005 13:43:50
 Re: Shifting Problem in reply to R.C.C., 02-24-2005 12:45:38
Did you pressure wash it and get it wet when you were done? You could have seised the shifting rods with some rust after it set. You should be able to see when you pull the shifter plate off. You may have also locked it into 2 gears when you put it together. Pull the top and take a look. Mark H.
