Tractor Talk Discussion Forum
hydraulics only work for short time.
roper
02-25-2005 21:54:07
I just bought a MF 205-4 2 cylinder diesel tractor with a front loader, the hydraulics only work for about 10 minutes when I first start it then they wine and will not work. Thanks for any help.
RickB
02-26-2005 03:41:04
 Re: hydraulics only work for short time. in reply to roper, 02-25-2005 21:54:07
Sounds as if the filter or screen plugs after a short time. Or perhaps the pump is worn and won't move warm or hot oil. Start with a fluid and filter change; make sure you don't miss a suction screen in the system. So many folks buy used stuff and put it right to work with little or no basic service.
Joe (Wa)
02-26-2005 21:55:12
 Re: hydraulics only work for short time. in reply to RickB, 02-26-2005 03:41:04
A pump that whines is usually air bound or running dry. Check those filters per Rick.
Joe
