Tractor Talk Discussion Forum
9N serial number Help
Kevin Lesmeiste
02-26-2005 19:57:51
I have a 9N I have looked for serial number found this number on the left side but was not attached to the engine, but it was just behind the engind block on left side ?AA909I8 and a diamond after the last number. The first letter appears to be a n or w
john in la
02-28-2005 03:33:58
 Re: 9N serial number Help in reply to Kevin Lesmeister, 02-26-2005 19:57:51
I got to agree with Scott. Looks like you have a 1954 NAA.
Does the picture below look like the place you found this #?????
third party image
Jim.UT
02-27-2005 19:57:54
I agree with Scott. That diamond after the number tells me you really have found the serial number. The first letter should be an N and there should be a diamond before the N also. So your full number should be <>NAA90918<>. Ford often used a capital "I" for a 1. Does it have an overhead valve 4 cylinder engine? Does it have a round emblem on the nose above the grille (or a round spot where the emblem used to be)?
A 9N will have a flathead 4 cylinder engine and the serial number will be stamped on the left side of the engine block on a 1" x 4" rectangular spot just below the head.
Here are a couple of sites that may help you nail it down.
Smith's 8N identifier page. This is a good one for identifying 9N, 2N and 8N Fords, but it also mentions the NAA/Jubilee. Just scroll all the way down.
Vintage Ford Tractor Resource serial/model numbers. This is a very good site for the NAA and later Fords (up through 1964).
Scott PA
02-27-2005 16:58:12
Sounds like you have a newer 1954 model NAA Ford tractor.
Bob
02-26-2005 20:09:51
The tractor serial number is found only on the engine block. The link below (if it is still active when you get to it) will show you where to look.
