Tractor Talk Discussion Forum
450 Diesel
greg806
02-28-2005 14:47:18
Does anyone know where I can find a carb.
overhaul kit for a 450 diesel? I would really
appreciate any ideas on this matter. Thanks, Greg
Bailey
02-28-2005 17:22:52
 Re: 450 Diesel in reply to greg806, 02-28-2005 14:47:18
I have an original operators manual for a W - 450 Diesel Tractor for sale.. Let me know if you are interested. Robert.
Farmaller
02-28-2005 17:05:12
www.batescorp.com
Mike S 806/H
02-28-2005 15:19:53
Go to the caseIH dealer you have to buy the parts in seperate
Hurst
02-28-2005 15:09:14
What do you mean a "carb." overhaul kit. A diesel engine has injectors and an injection pump, not a carb. Let us know, if you are talking about the injector, I would get that professionally rebuilt (they have very little tolerance for error). Goodluck
Jaker
02-28-2005 15:40:18
 Re: 450 Diesel in reply to Hurst, 02-28-2005 15:09:14
Hurst,
IH had used a diesel that was started on gas and swithed over to diesel once it is warmed up. So it is both a spark ignition and a diesel engine.
720Deere
02-28-2005 15:38:02
Hurst,
The Farmall 450 diesel starts on gas and switches over to run on diesel. This system was used by IHC for many years and the 450 was the last series tractor to use it. The 560 which replaced the 450 had glow plugs.
sawtooth
02-28-2005 15:42:33
 Re: 450 Diesel in reply to 720Deere, 02-28-2005 15:38:02
That's interesting. With the high compression ratio for diesel how would you avoid pre-ignition with gas? And what about spark plugs- in a diesel?
RN
02-28-2005 17:56:57
 Re: 450 Diesel in reply to sawtooth, 02-28-2005 15:42:33
'Gas' mode compression ratio about 6 to 1 on IHC. Spark ignition chamber open by small third valve in head- could call it a compression release. Nearest modern sort of example might be Honda CVCC of 80's civic- precombustion chamber with rich mixture intake, 3rd valve for easy start and run, lean mix in main combustion chamber. IHC when running Diesel mode about 14.5 to 1 compression ratio, third valve closed in all cylinders, gas shutoff to carburator, injection of diesel fuel only directly into cylinder. RN.
wolfmantractor
02-28-2005 15:53:38
They were special spark plugs-massive.(I still have a new one in the shop). There was a compression release for when it was running on gas. I always switched to Diesel & swung the compression lever simultaneously. Actually amazing set up for it's time.
