Tractor Talk Discussion Forum
OT... Replacing car strut
TractorMike
02-28-2005 15:55:31
Hi all, I am in the process of replacing the strut on my car and figured out pretty fast that I need a spring compressor and I was wondering where I can get one of those? Would the auto parts store have that or maybe Sears??? Just wondering. Thanks, TractorMike
1945 A
03-01-2005 07:35:35
 Re: OT... Replacing car strut in reply to TractorMike, 02-28-2005 15:55:31
I was able to rent a spring compressor when I decided to replace the struts on a little Buick my wife drove a few years back. After that 1 experience, I decided that future strut changes were going to be done by someone else!\
Those springs are under a LOT of compression, and 1 slip of the adapter could be hazardous to your health!
The other thing is, that you'll end up having to get the front end aligned afterwards anyway----I drove that little Buick to the alignement shop with the tires squaealing most of the way--(about 10 miles).
If you decide to do it yourself, though, rent/buy a good tool, and keep head, extremities, etc as far awy as possible from the compressed spring....
caseyc
02-28-2005 18:54:16
don't forget about an alignment! the lower bolts on most cars are also the camber/caster adjustment. once you get the new struts in you'll have to go visit your friendly neighborhood shop for a alignment.
casey in SD
mj
02-28-2005 18:54:07
I've got a Harbor F. compressor that was about 15 bucks. I've replaced 2 or 3 sets of struts with it and I learned one thing about it and that is take off the tire and wheel that you are working on and jack that corner up as much as possible. This compresses the spring more so that the spring compressor doesn't have to be taken up as far against a load.
Gerald J.
02-28-2005 17:47:23
Sears probably not, a good car parts place might have an adequate spring compressor, the best investment is a tool rental store.
Gerald J.
Allan in NE
02-28-2005 16:34:13
Hey Mike,
Those are some pretty hefty springs/compressors. I think for a one time deal like you're doing, I'd just take both the old and new struts to a garage and have them press 'em for you.
Wouldn't take 15 minutes and probably save you $400 on a good compressor. If it is a GM you are working on, you're probably going to need the proper adaptors anyway.
Allan
kjm
02-28-2005 20:02:08
 Re: OT... Replacing car strut in reply to Allan in NE, 02-28-2005 16:34:13
T.M.,I agree with Allan take the strut to a garage to switch the strut in the spring. The last one that got away from me the bearing went 15ft up hit and landed 30ft away.We went out and bought a good compresser with a safty lock $550.00 about 10yr. ago.We charged 10.00 to change struts out for people. KJM
rustyj14
03-03-2005 11:57:30
 Re: OT... Replacing car strut in reply to kjm, 02-28-2005 20:02:08
When my son was 14 yrs. old, he had a Nash Rambler 2 door, in which he had installed a Ford engine! (Without my help!) So, the front coils weren't strong enough to hold the car level, so, He took the car down to the local gas station, where all of the locals hung out, and, with 4 big fools setting on the opposite rear 1/4 panel, they managed to get the spring out! After they had chased the spring down the road, they set about trying to get the new one in! Naturally, nothing worked--the 4 goofs on the opposite 1/4 panel did nothing! I tried to convince him to go see Uncle Joe, who had worked at a Nash dealer, and had a spring compressor, so after much trial and error, with a commercial compressor, the compressor parts slid together and resulted in a large u-shaped coil spring! After tossing the spring up in the air about 20 times, the spring straightened out, and the son went to see Uncle Joe! Next trick was to get the spring compressed enough to install the clamps, so, under the grease rack went the coil spring--and--out it came in a rush! After many tries, he finally got it to hold, got the spring back in place, did the other one, and said never again! (The Rambler didn't have shock absorber struts, but it did have a seat and strut assy that was the fore-runner of struts as we know them today!) by: Rustyj
