Tractor Talk Discussion Forum
O/T '96 Chevy truck clutch/pressure plate question
Jonboy
03-02-2005 08:16:39
Well, I guess it's time my rock goes in the shop because the pressure plate has gone bad. Looking for advice weither I should replace the clutch disk and throw out bearing as well or leave those alone as I haven't had any trouble from those as of yet, no slipping. I have no clue how many miles are on that clutch, truck only has 75,000 miles and the guy I bought it from had totally babied it and had never hauled anything or ever left the pavement with it, so I'm thinking it's probably the original. What do you think?.
shannon from ohio
03-02-2005 17:44:07
 Re: O/T '96 Chevy truck clutch/pressure plate ques in reply to Jonboy, 03-02-2005 08:16:39
Also make sure you inspect the clutch fork and ball pivot for excessive wear and replace if worn
leland
03-02-2005 09:50:34
You may as well spend the few xtra bucks and have the `fly wheel turned also and make sure they put a shim behind it the same thickness as what they shaved off of it. This make a lot of differance on how long you new one lasts. bacause if the clutch went at 75000 he rode the heck out of it and the flywheel is scorched,I usually get 150+ out of one and I load the heck out of my trucks.
Redmud
03-02-2005 09:12:21
And don't forget the pilot bearing, if it's bad, it will make you think your pressure plate is bad.
forgot my password
03-02-2005 08:39:15
If you even suspect that it is all original it makes no sense not to replace it while it"s apart.
the cost of the parts can"t be all that much...
if I remember my last clutch replacement, the pressure plate was the expensive part.
just my 2 cents
Allan in NE
03-02-2005 08:32:25
Jon,
You already know the asnwer to this one.
Just like a darned T/A. Replace every blessed thing in there so's ya don't have to make the return trip. :>)
Allan
Jonboy
03-02-2005 08:37:46
 Re: O/T '96 Chevy truck clutch/pressure plate ques in reply to Allan in NE, 03-02-2005 08:32:25
Thats probably a good idea. I was just wondering if it was common practice to replace everything while part of it was seen to, even though everything else seems ok. But I guess clutches usually go pretty fast once they start.
Thanks
Bob
03-02-2005 09:20:50
 Re: O/T '96 Chevy truck clutch/pressure plate ques in reply to Jonboy, 03-02-2005 08:37:46
You can buy NEW clutch kits, with the 2 bearings, pressure plate and lined plate all included so reasonably it makes NO sense not to replace everything, while you're in there.
Jonboy
03-02-2005 09:49:47
 Re: O/T '96 Chevy truck clutch/pressure plate ques in reply to Bob, 03-02-2005 09:20:50
Where do you find clutch kits. Also, are Napa clutches ok or are they junk?.
Thanks alot!
leland
03-02-2005 09:52:34
 Re: O/T '96 Chevy truck clutch/pressure plate ques in reply to Jonboy, 03-02-2005 09:49:47
We have a local clutch and brake shop slip one of the guys 25.00 and he will rebuild it during his lunch break andyou only have a short amount of down time.
