Tractor Talk Discussion Forum
Cummins Tools
Tweeter
03-03-2005 07:20:37
Are Cummins Industrial Tools any good. I am looking a floor model drill press. 3/4 Hp.
John *.?-!.* cub owner
03-04-2005 19:29:52
 Re: Cummins Tools in reply to Tweeter, 03-03-2005 07:20:37
About the same to slightly lower quality than Harbor Freight.
Don c
03-04-2005 03:31:32
About the only thing I buy is there grinding goggles and grinding face shield replacements, kinda hard to go to far wrong on these. Good price on this stuff.
37 chief
03-03-2005 15:35:33
Looks like you got your answer. Well over half of responses say the stuff is junk.
mike in New Mexico
03-03-2005 11:06:57
Bought a drill press about 2 years ago and can't keep the chuck in, also bought a drill vise (junk)-mike
BB
03-03-2005 10:01:12
Limited experience. Bought a 14" metal chop saw that worked fine until it was stolen. Bought some vise-grip type (but not name) welding clamps. Those also work fine.
bj/8n/mt
03-03-2005 09:50:16
I have one of their floor model drill presses. Bigger than the one you are talking about. The fit on the chuck taper [M-2} is so bad I have tried shimming it with everything from brass bearing shim stock to newspaper and it has never been right. Check that before you fire up your check book.
Your mileage may vary
thejdman01
03-03-2005 09:04:46
i have had ntohign but bad luck with the traveling clowns. again freight if you ever have any problems or trouble will kill you. locally star line a very very cheap and knowledgeable local that does any electric work anything at all from starters off a toyota to a starter off a dresser loader and rebuilds computers circuits anything electrical this guy is a real gooru and works very cheap 30 bucks usually labor for a total teardown of a starter or altenator and rebuild. he even bumps altenators. like for my 6.5 diesel the chinsy 80 really wouldnt cut it with the plow on etc and he bumped it to 160 amp and replaced brushes and bearings regulator while he was in there for 110 bucks you cant even go to the parts store and get a rebuilt 80 amp for under 150 but anyways going off on a tangent had a cummins drill press once and motor burnt out took it to him and he said it was the biggest piece of junk he had ever seen poor quality poorly made cheap. wnded up putting different pullies, motor etc on it now aint too bad. as much as i hate sears i would go somewhere that you can take it back yourself. some of those traveling shows have real good deals especially for the homeowner but some are real flyby nights
mike
03-03-2005 08:47:49
I bought thier bench type 3/4 hp drill press for about 50 bucks. it doesn't complety stink... don't get any ideas of drilling 1/2 inch holes in 1/2 inch flat stock- not gonna happen. drilling some light angle it's ok.
TimV
03-03-2005 08:42:08
Tweeter: Most of what Cummins sells is the same stuff that Harbor Freight, Northern Tool, Enco, Grizzly, Homier, etc. sells--namely inexpensive China-made tools. If you can live with that, then their tools are no better or worse than the rest of the above vendors. I've purchased many things from their travelling shows (which show up in our area a couple of times a year) and have always had good service and no hassles on the times I've had to return a broken tool. I'm not saying that everyone will have the same luck, but I've found the Cummins reps to be much more knowledgeable (and honest for that matter) than most.
Pat L
03-03-2005 08:16:23
JUNK JUNK JUNK I bought a drill press from them and used it to drill 2 holes They were still in town took it back and they said need to send it to manufacturer 154.00 freight each way still have it to remind me why not to buy their junk
mike brown
03-03-2005 09:13:06
 Re: Cummins Tools in reply to Pat L, 03-03-2005 08:16:23
My Cummins purchases:
Air commpressor...stll working fine 4years later
3/4"drive socket set...sockets break with arm strength only
screw drivers...turned out to be chrome plated brass.
Porter Cable air stapler...good
aluminum carpenters squares... had to use a milling machine to mill them...square!
Floor jack...good
Reman. power washer...good
So it's a crap shoot. Be picky, buy name brands when you can. You still get what you pay for.
