Tractor Talk Discussion Forum
Old tire as a gravel harrow?
gascolator
03-06-2005 10:14:12
Someone told me that when he had a load of
gravel brought to his driveway that the old
gent dragged an old tractor or truck tire on
a chain around to level and smooth the gravel.
Anybody ever heard of this?
What kind of lash-up do you use? Seems like
it should work.
skipper
03-06-2005 19:06:02
 Re: Old tire as a gravel harrow? in reply to gascolator, 03-06-2005 10:14:12
I have used old chain link fence for leveling soft soils in times past. Also works great as a mat to drive over soft soil or sand.
Sid
03-06-2005 18:59:22
I made one with rear backhoe tires. I used a two inch pipe to hook them one to and staggered the lenght of chain where every other one is about eight inches shorter. This lets them over lap a little. Then I use a cable about two feet from each end and hooke to the tractor with that.I use it do drag out gravel to drag pastures in the spring and also to drag plowed ground. It works for me.
Sid
03-06-2005 18:59:18
Redmud
03-06-2005 16:08:47
This is what bed springs were made for. And sometimes you need an old sheet of plywood to lay on top of the springs so you can add weight.
aaron from wisconsin
03-06-2005 15:43:09
up here in the north thats what we use too is an old bed spring. works good have fun with the tire.
jonsmall
03-06-2005 16:07:38
 Re: Old tire as a gravel harrow? in reply to aaron from wisconsin, 03-06-2005 15:43:09
we do that in the spring after we plow my driveway to make all the gravel level. and we ise them to cover the ots after we plant too.
leland
03-06-2005 15:12:10
old RR ties work good also .
RickL
03-06-2005 14:41:49
use an old feederhouse chain out of a combine it really works. just lay it out and pull from one end
Kirk Grau
03-06-2005 14:08:07
Here is a link to a site with all kinds of plans for home built stuff. This one shows tires bolted together to make a drag. I did this and pull it behind the mower to break up manure piles in the pasture. Works pretty well, but not as well as I would like. The tire drag plan is #6212.
Link
36BinMN
03-06-2005 11:10:55
Sounds like it would work pretty good. I think I would use an old tractor tire my self. To hook up to it instead of wrapping a chain around it, you could drill a hole through the tread near the bottom (when laying flat) and put a big eye bolt through it with a plate or BIG washer on the inside with a nut. Sounds like it would work!!
Bob
03-06-2005 10:25:58
How about using some real "redneck engineering", and using an old bedspring?
gascolartor
03-07-2005 06:03:01
 Re: Old tire as a gravel harrow? in reply to Bob, 03-06-2005 10:25:58
You might be a redneck if you drag the bedsprings
behind the tractor to level the road, and your
wife's 650-pound cousin 'Beau' is still laying
on 'em eatin a box of Krispy Kreme's and watchin'
the Reverend Lee on the portable.
