Tractor Talk Discussion Forum
Oil Seals
msb
03-10-2005 16:59:14
Any place on line to cross reference oil seals.Have some National and Victor seals to run down for the old Massey.I have the dimensions.One good thing Massey Harris did in their parts books.Thanks,bob
Joe (Wa)
03-10-2005 21:33:27
 Re: Oil Seals in reply to msb, 03-10-2005 16:59:14
Here is a good cross-ref link that has a lot of older tractor part nrs. If your tractor p/n will not cross at chicago-rawhide.com, try the link, it may cross to a Natl or US Seal nr that in turn may then cross at the CR site for sizing.
Joe
Davis In SC
03-10-2005 18:51:47
Most bearing houses are glad to help, They can work from old part numbers, or by measuring, if you bring old seals. They do this all day & most of the employees are quite knowledgable. It is surpising how inexpensive parts are at those places. Years ago, I needed a wheel bearing for an old Land Cruiser. Was 40 dollars at Toyota dealer, but not in stock. I went to a bearing house & got one for 4 dollars..... ...
TDK
03-10-2005 18:51:06
Go to chicago-rawhide.com . Click on the "site map" icon on upper right of page. Scroll down the page and click on one of the four choices of "interchange -parts lookup". Can be cross referenced by brand part no. or dimensions. This is how I do it. Take the C/R numbers to auto parts store and they can, if they will, find the seals for you. P.S.- some of the large seals may not be avaliable except through tractor dealer, but most of them I get this way. Hope this is what you were looking for !
msb
03-10-2005 19:54:39
 Re: Oil Seals in reply to TDK, 03-10-2005 18:51:06
Hey,THANKS TDK.That was exactly what I was looking for.There was no listing for the PTO lever seal,but I used the measuremnts to generate a CR part number.I also ordered thier catalogs so I won't have to go though that process again.Thanks again,bob
Mike M
03-10-2005 17:33:20
I did find a source for real cheap ball bearings. They may also sell seals ? www.skatebearings.com that should pull up a web site with a phone number too. give them a call. fast and cheap shipping too.
Kevin Bismark
03-10-2005 17:28:24
I hope someone knows a place, I went to several auto parts places with old chicago rawhide numbers and dimentions and they had no idea what I was talkiing about, I remember when the older guy"s that knew something worked at these places, I could bring in a seal, or bearing and they could find me almost anything, but haven"t had much luck now day"s...
