Tractor Talk Discussion Forum
How to Break an Old Weld
JKC
03-11-2005 19:43:28
I have discovered that many years ago, someone welded one of the cultivator brackets onto one of my old tractors to give the cultivator "extra support", I guess. The question is: This bracket was welded directly to the cast on the tractors front end. What is the best way to break this weld and remove this bracket? ANY suggestions would be very much appreciated.
leland
03-12-2005 18:30:04
 Re: How to Break an Old Weld in reply to JKC, 03-11-2005 19:43:28
Whats wrong with a carbon arc rod to burn thru old weld? this seems to be the easist way that I can think of goes thru welds like a knife in butter
Allan in NE
03-12-2005 05:59:15
JKC,
I agree with the others on the use of an angle grinder, but with one exception.
Put a cutter disc on the grinder first. They sell these things everywhere. You'll have that old weld cut faster than you can fire up the torch.
Try it; it really works fast! Like a knife thru butter.
Allan
third party image
skipper
03-12-2005 17:22:57
 Re: How to Break an Old Weld in reply to Allan in NE, 03-12-2005 05:59:15
Allen I declare -- Could it be? that looks like a duct tape benchtop?? Pretty cool.
dr.sportster
03-12-2005 04:26:21
Always treat cast iron like its brittle.Because it is brittle and hard to repair.
T_Bone
03-12-2005 02:00:22
Hi JKC,
As stated by Eldon, use a grinder with a thin blade and cut just above (couple thousandth's) the casting surface until you see a black line.
This black line will be the seam between the two mated piece's. When you see the black line then your piece will come off very easy.
Don't see a black line? Then your cutting too high or too low of the seam.
Most welds will be about 1/8" deep penetration on both piece's.
I agree that too much hammer on castiron will most likely break the castiron. Cut to the black line then use a very light tap, if needed.
T_Bone
Davis In SC
03-11-2005 21:03:42
Good advice below..... Murphy's law says breaking a weld always pulls a big chunk out of the side you want to save.....
Tony Gardiner
03-11-2005 22:40:57
 Re: How to Break an Old Weld in reply to Davis In SC, 03-11-2005 21:03:42
Don't try, to break the metal off, when trying to remove welded portions off cast metal, you will probably break the casting, which has had it's surface damaged by the heat of welding.
Get a good full helmet with breathing filters, and face shield, leather gauntlet gloves, and cut the welds with metal cutting discs on a 9" depressed centre, electric mobile grinder, with metal cutoff blade ( 7" will do ).
You can't go round corners, so you will have to cut chunks off, watch the sparks !.
Eldon (WA)
03-11-2005 20:18:33
Take an angle grinder and grind as much weld off as you can get to....hit with a big hammer to break bracket off, then clean up with angle grinder.
Don L C
03-11-2005 20:39:08
 Re: How to Break an Old Weld in reply to Eldon (WA), 03-11-2005 20:18:33
Eldon --- has has the only answer you will need..... ..... ..
Jerry Cent. Mi.
03-12-2005 05:45:21
 Re: How to Break an Old Weld in reply to Don L C, 03-11-2005 20:39:08
Cut off as much of the bracket as possible with a torch. Grind off the rest with a right angle grinder. Use the other options if you want to save the bracket. Good Luck.
