Tractor Talk Discussion Forum
1066 steering slow
john paul
03-12-2005 05:15:44
i just bought a 1066 ih a 72 model it only has 1500 hrs on it . its been settin in a barn since 1983, we got it out got it running and the hyd works good so does the remote, the steering dont work at a idel but if you rev it up the steering works, but acts like its on slow motion, what valve would control the steering , were is it located, thanks
Jeff Oliver
03-12-2005 06:03:22
 Re: 1066 steering slow in reply to john paul, 03-12-2005 05:15:44
Is the steering really hard to turn or is it just slow? if it is hard it might be the thrust bearings on the spindles needing grease or replacing. I have an 1800 Oliver that is doing something like that and I think I am going ot check those next on it.
Allan in NE
03-12-2005 05:36:41
Hi John,
That's probably why it has been setting for so long? :>(
The steering is the first item in the food chain for the output of that front pump and gets priority. Is the bypass squealing? Maybe change the oil and filter?
How do the brakes, T/A and clutch work? They come in line after the steering and if they are sluggish as well, you might need a front pump (seems odd tho, at 1500 hours).
Maybe the old sister just needs to be taken out and limbered up again.
Hope ya get 'er figured out,
Allan
