Tractor Talk Discussion Forum
Permatex ?
msb
03-12-2005 16:26:55
Replacing an axle seal and making new gasket/shims.Need .004" more with the gasket material I am using.Anyone ever check to see how much a heavy coat of Permatex will add if any?Guess I could use some onion skin paper.
TimV
03-13-2005 06:18:08
 Re: Permatex ? in reply to msb, 03-12-2005 16:26:55
MSB: You can get 0.004" with permatex easily enough, but the key is letting it set up before tightening the joint. The down side of this method is that unless your initial bead application is smooth, you can end up with uneven torque.
dr.sportster
03-12-2005 21:06:23
When you shim the cams on a Sporster dry and then final install cover with aviation permatex it makes no change.It must squish right down .
Joe (Wa)
03-12-2005 21:00:58
I don't think you will get anything measureable with permatex. Even non-metallic gasket material is marginal unless you can check the clearance after clamping and add or delete. Compressibility is too unpredictable.
I would use metallic shims. We used to use plastic gaskets on hydraulic pumps & motors for clearances way back when, but they required a specific & accurate torque by application.
Joe
fixerupper
03-12-2005 18:38:24
You don"t need to use a gasket sealer.
msb
03-12-2005 19:50:41
 Re: Permatex ? in reply to fixerupper, 03-12-2005 18:38:24
That wasn't the point.It is for its thickness.
