Tractor Talk Discussion Forum
IHC 4100
JOE BUSH
03-15-2005 13:16:01
I AM LOOKING TO BUY A 1970 4WHEEL STEER IHC 4100 4WD,IT HAS BEEN SITTING OUTSIDE FOR 10 YEARS WITH A BAD CLUTCH,THEY WANT $2000.00 FOR IT WHAT IS THE VALUE OF THIS TRACTOR NOW AND IF IT WAS IN GOOD OPERATING CONDITION.CAN SOMEONE REPLY,THANKYOU
Mike (WA)
03-16-2005 08:24:08
 Re: IHC 4100 in reply to JOE BUSH, 03-15-2005 13:16:01
These big old machines are "betwixt and between"- anyone farming big enough to use a machine that size has to use a newer machine for reliability, and collector value is very limited because it's too big to haul to shows, doesn't fit in any puller class, etc. I think James2 was right on the mark.
James2
03-16-2005 05:31:35
The tractor weighs about 15,000 lbs, making it worth as scrap around $1000 after subtracting tire weight and tire disposal cost. I bought a good running 4166 with AC and 3point for $3000. Tires had 40% tread. Converted to 134a, changed all fluids and put in a cab kit. Although I think it was a pretty good buy, the question is, who wants one? I believe the market for these machines is very limited. I don't believe that it is worth more than about $1200 to $1500.
JDknut
03-16-2005 04:11:03
If it runs it might be worth that, but with no clutch you are barkin' at a winch truck to haul it. If it was in good runnable shape, I'd think it would be worth 6 to 8K. One thing is that those big IH 4 wheelers were made by the Frank Hough (of Payloader fame) construction equipment division which is a good thing in that Hough knew how to make good tough construction equipment but a not so good thing in that they are now orphaned in terms of getting parts, being part IH and part hough. Might have some luck at a Dresser dealer as Dresser took over Hough when IH went down the hopper. Definite collector value for a dyed in the wool IH fan, tho.
ChrisL
03-15-2005 19:33:31
Right now that tractor is worth scrap price minus what it takes to pay someone to load and get it there minus the deductions - -
if you fix it all up and getting it running again it will be worth scrap price plus $100 (it will be easier to get it to the scarp dealer.....)
