Tractor Talk Discussion Forum
Case 580B info needed
52RM
03-18-2005 10:22:46
Hello,
I now own a Case 580B backhoe ,Could anybody tell me what transmission set up I have ?
It has a lever next to the steering wheel for fwd/rev..And a 4 speed trans,WITH another shifter in front of that,It also has a gas pedel on the right..The tractor needs a ring and pinon ,So I cant drive the tractor to see what these levers do..Any other info on this 580b you could tell me would be helpful....
I Thank You for your time !!
Al. Thanks
the tractor vet
03-18-2005 11:24:44
 Re: Case 580B info needed in reply to 52RM, 03-18-2005 10:22:46
It is the stanard gear drive and that is a good thing but you need a ring and pinion and that is a bad thing , i know that they are hard to come by and are big bucks and after working on one 580 B i do not look foward to the next one . I had to replace a foward reverser in one that had a toqure converter for a guy back several years ago and what i went thru on that one and the cost of it his good deal went south fast he gave way to much for it to start with and the new reverser was almost 4 grand and with labor he had al most 18 grand in it . I do not know where to tell you to find the parts as this is one of them things that is common on them.
