Tractor Talk Discussion Forum
Parts needed for homebuilt tractor
Casenut
03-18-2005 17:39:59
third party image
I have built a tractor back in 1985 and used a right angle gear box from a piece of machinery for the belt pulley but cannot remember whatit was from. The gears broke inside of it and am in search of replacments. The gears are 90 deg. angle gears. One has 40 teeth and the other has 20 teeth with 1" shaft and keyed on. I do not need the gear box but I will describe it and post a drawn picture. The box was painted red when I got it. It is made of steel (not cast) it has a tin cover screwed on with 3/16 stove bolts, it measures approx 6" long, 4" wide and 5" high, it has 1" shafts and uses flanget bearing on the through shaft and has a bushing on the side shaft, there was an 1 1/2" pipe welded to the bottom (do not know how long it was) If you can identify the box or know where I can get some gears please let me know. Casenut
cdmn
03-20-2005 17:10:43
 Re: Parts needed for homebuilt tractor in reply to Casenut, 03-18-2005 17:39:59
To me it looks like a Hub City gear box, made I think, in Aberdeen, S.Dak. Shouldn't be too hard to find and not too expensive. Try also >Link
Lots>Link of gearboxes on E-bay.
Bob
03-19-2005 02:02:15
Have you checked Surplus center? You may be able to fid a new gearbix for less than special-order parts would cost you.
Davis In SC
03-18-2005 17:52:05
A good bearing house should be able to get the gears you need... Chances are that gears were standard off-the-shelf to start with... Here in the Southeast, we have a great bearing & power-transmission place..... Bearing Distibutors,Inc. Look in the Yellow Pages under Bearings... Most of those places have a lot of knowledge about gears..... Just walk in with a smile & tell them you need some help..... Davis
jc
03-18-2005 19:22:59
 Re: Parts needed for homebuilt tractor in reply to Davis In SC, 03-18-2005 17:52:05
Thats good advise. we have a couple places like that here. I can sometimes call in with a description and get help. One place has a female counterperson with as much or more knowledge as the guys there. Imagine that.
