Tractor Talk Discussion Forum
OT/F250 trans
WiCraig
03-20-2005 06:49:49
I have a ford 1991 F250. The mechaic tells me the tourqe converter is shot and a tranny will cost about $1800. I'm thinking about just junking it as there are some other problems with the truck. Question finally, can't just the tourqe converter be replaced, not the whole tranny? Thanks Craig
raytasch
03-21-2005 06:33:54
 Re: OT/F250 trans in reply to WiCraig, 03-20-2005 06:49:49
That would have the E4OD as said earlier in this thread. That tranny was designed for passenger car use and is weak for truck service. The tranny was upgraded sometime around 1995 and is improved some. Mine has been rebuilt twice by Ford, last time about 40K miles ago. It was upgraded at that time and seems to do well now. When the torque converter fails it throws trash through the rest of the tranny as mentioned earlier. Clean fluid and filters are required for the E4OD to have any life at all. Do a search on E4OD and you can read for weeks about this tranny.
ray
Ron F
03-20-2005 23:28:03
What did they put in the 97 F250 heavy duty's and what is their history? 7.5 gas motor.
tn terry t
03-20-2005 16:45:21
what you have my friend is a e40d trans i have not and will not buy a used one.these trans are weak from the start 1800 IS right in line price wise heck i have one out on my grease rack as we speak. im fixen to put a C-6 in place of it and see if i can make it shift the e4od is electronic controlled .my dad give 1700. dollars and it lasted 30000 miles so im gona try a different route this time
Redmud
03-20-2005 10:32:59
I just had a 400 in a 3/4 ton chevy rebuilt, it was just over $600.00. If yours is a C6 it shouldn't be much higher. Depends on what part of the country your in I would guess.
Jonboy
03-20-2005 08:23:52
Nah, don't pay no $1,800 for a tranny for that. Cruise around looking for a junk truck in someones back yard, if you find one in someones back yard you could probably buy the whole thing for $500, granted the truck would be junk, but if the tranny was ok then you'd be ahead by quite alittle. You might also take out an ad in the local paper in the parts section and find one for a whole lot less that way. I don't know where your at, but most of the trucks of that year have already been junked as the bodies rust out before the drivetrain goes due to all the roadsalt used in the winter. The scrapyards are full of them also, so you migt want to give them a call, and last I knew the scrapyards allowed you to bring something like that back if it was no good.
Hope this helps!
earlschieb
03-20-2005 07:30:18
I would think that $1800.00 is a little high, I could get it done down here for about $1200.00, maybe he is doing an exchange unit, which could possibly make it cost a little more. If you have it done, make sure that the tranny cooler, and lines are all back flushed, or you will have the same problem again shortly.
Allan in NE
03-20-2005 07:04:22
Craig,
The torque converter is the last part that I would think has failed. What is your truck's symptoms?
Allan
earlschieb
03-20-2005 07:13:43
 Re: OT/F250 trans in reply to Allan in NE, 03-20-2005 07:04:22
Allan, the Torque Converter disentigrates in them, then the pieces from the converter plug the tranny cooler, no cool fluid for tranny, and burns up the rest of the tranny. I have a friend who has a tranny shop, and this is a regular thing with that era, so I imagine his tranny is shot also now.
