Tractor Talk Discussion Forum
Diesel fuel in engine oil
ags1
03-24-2005 09:25:26
Draining the engine oil from the pan, the oil comes out very thin and smells like diesel fuel, I think I have a problem, any ideas?
TomTX
03-25-2005 05:34:59
 Re: Diesel fuel in engine oil in reply to ags1, 03-24-2005 09:25:26
Yes, it is more than likely the lift pump, not the injector pump. On MF/Perkins the lift pump diaphram will crack and leak fuel inot oil. Cheap easy fix.
thurlow
03-24-2005 11:22:44
As Bob suggests, the first place I'd look would be the transfer pump, assuming you have one...
farmall puller
03-24-2005 10:15:38
more than likely you have a injector pod bad in the head and leaking by and getting in the oil
Bob
03-24-2005 09:58:09
It would help to know what you're working with!
Obviously, leaky injection pump shaft seals are always a prime suspect.
If the unit has an engine-mounted fuel lift pump, if that fails diesel will drain into the oil.
Bad injector(s), or a broken high-pressure or return line can leak into the oil (if the lines are INTERNAL on the engine you're working with, as they are on certain engines).
Sloroll
03-24-2005 09:34:41
Seals in your injector pump are going bad. I'm assuming of course it is a diesel tractor.
ags1
03-24-2005 12:03:46
 Re: Diesel fuel in engine oil in reply to Sloroll, 03-24-2005 09:34:41
Engine with fuel in oil pan is a Perkins A4-236 in a Massey 265.
the tractor vet
03-24-2005 12:22:22
 Re: Diesel fuel in engine oil in reply to ags1, 03-24-2005 12:03:46
Replace the lift pump on the side is my guesstamation you have the Cav injection pump and i have not seen many of them with a bad seal not sayen that is not the problem but have seen more leaking lift pumps.
