Tractor Talk Discussion Forum
Which Oil for Ford 3000 Gas Tractor?
Richard Koch
03-27-2005 16:34:37
Hi, Just bought a 1969 Ford 3000 gas engine tractor. It has in the 3000 hour range, does not smoke or use oil. What brand and weight is best for this tractor? It is in Misouri
Thanks!
Rick
Leland
03-28-2005 17:46:09
 Re: Which Oil for Ford 3000 Gas Tractor? in reply to Richard Koch, 03-27-2005 16:34:37
I agree 15-40 shell would be the best can't beat shells gaurantee either and it's not over priced
cockshuttguy
03-28-2005 17:28:38
I have a '70, 3000. Always used shell oil.
Used straight 20 or 30 til it was no longer available. Now we use a 15-40 Rotela T.
Engine has 4000 plus and doesn't use a drop season to season.
Good Luck.
Rod F.
03-28-2005 08:38:22
Use a good quality diesel rated engine oil. Generally, I use 15W40, unless the tractor does a lot of cold starting, then I use 10W30. Even though your 3000 is gasoline powered, the engine was designed primairly as a diesel, and a good quality diesel engine oil (CI rating) should be used. This will provide a better level of protection than an SJ rated engine oil in an ag application. HTH.
Rod
Corey DeLong
03-28-2005 04:28:32
I use a good quality 10w-40 in my 961 gas.
sammy the RED
03-27-2005 23:22:03
Use a good quality 10w30.
old
03-27-2005 19:36:57
I use Valvoline raceing oil 30 or 40 weight in all my tractors, I'm also in Missouri by the way.
Jerry/MT
03-27-2005 18:16:18
I don't know what temperatures you are operating in but 10w30 and 10W40 are good starting points. Nothing wrong with 15W40 if the temperatures are on the warm side but my experience with it was it's a little to viscous for easy starting in our western Montana climate except in the summer.
Jim K
03-27-2005 17:14:21
15-40 is what I use in mine.
Jim K
