Tractor Talk Discussion Forum
Try again
TGIN
03-30-2005 06:27:01
No help at farmall board so I`ll try here . My 574D INT. hydraulic pump will not shut off . It runs at high presure all the time other than when rasing the 3 pt. I`m thinking I have a stuck valve but which one ? Thank for any help !!
paul
03-30-2005 08:38:31
 Re: Try again in reply to TGIN, 03-30-2005 06:27:01
I'm a hyd dummy, but an open center pump should not, of course, ever shut off. It constantly cycle oil.
What must be happening is that the oil is going through your bypass, creating pressure? And heat, etc.
So, why? Something got plugged, or you have something hooked up wrong. Did you make any changes to the plumbing? Stick in a closed-center valve?
Otherwise, something in a power beyond port or the low-pressure return to sump must be plugged.
--->Paul
TGIN
03-30-2005 09:48:18
 Re: Try again in reply to paul, 03-30-2005 08:38:31
I have the loader off of it with the hoses pluged , would that make it act like there`s a plug ?
paul
03-30-2005 10:37:14
 Re: Try again in reply to TGIN, 03-30-2005 09:48:18
There you go.
If you left the hyd valve on the tractor, it should not be the cause. If you took the valves & all off, you just blocked up the oil flow with your plug.
--->Paul
TGIN
03-31-2005 02:48:37
 Re: Try again in reply to paul, 03-30-2005 10:37:14
That was it . I should have known that , sometimes we need a jump start to get our brains working . Thanks
JMS/MN
03-30-2005 12:45:10
Would it be like on a JD combine, when you disconnect the reel drive motor you must hook the hose ends together or the pump burns out?
