Tractor Talk Discussion Forum
LEAK ON ENGINE BLOCK ON MY 9N FORD TRACTOR
JAMES BRINKMAN
03-30-2005 13:33:04
I HAVE A COOLENT LEAK ON THE LEFT SIDE OF THE ENGINE BLOCK BY THE THE OIL FILTER. IS THERE ANYWAY I CAN FIX IT BESIDE WELDING IT? IT IS MORE OF A SEP THEN A LEAK. THANKS JIM
Gerald J.
03-30-2005 16:23:15
 Re: LEAK ON ENGINE BLOCK ON MY 9N FORD TRACTOR in reply to JAMES BRINKMAN, 03-30-2005 13:33:04
Go easy on the shouting.
Might not be a crack, might be a threaded fitting that has worn from vibration over the past 60 years. You could replace the fitting or remove it and apply a good sealant, like Rectorseal #5 (plumbing department of a home center will have it), and run the tapered fitting back in maybe an extra turn.
Gerald J.
Pitch
03-30-2005 15:55:50
Thats the most common place for those to crack from lack of antifreeze.
There is not a lot of pressure there so it does not need wellded. Wire brush the whole area to bare cast so you can see the extant of the crack. You probably want to drill a small hole at the end of the crack to keep it from running any further and the using an angle grinder carefully and gently v out the length of the crack. clean the area completely and apply JB Weld. You can even press a coarse sandpaper into the weld to simulate the casting grain, paint your favorite color and your done.
JAMES BRINKMAN
03-31-2005 14:31:57
 Re: LEAK ON ENGINE BLOCK ON MY 9N FORD TRACTOR in reply to Pitch, 03-30-2005 15:55:50
THANKS PITCH. I WILL TRY IT AND HOPE IT WILL WORK. THANKS AGAIN.JIM
