Tractor Talk Discussion Forum
IH 454 (2400A) Hydraulics?
Les Chapel
03-31-2005 06:59:44
I don’t have a remote hyd block to plug in hyd lines for accessories. I’d like to add a loader but I don’t know where to look for hyd line access. This doesn’t have a front pump but has lines running up front to an oil cooler. I’ve removed sheet metal to clean and have visualized the hyd lines and so forth, I'd just like to know what goes where... thanks E-mail unblocked.
geok
03-31-2005 19:42:48
 Re: IH 454 (2400A) Hydraulics? in reply to Les Chapel, 03-31-2005 06:59:44
You can connect to the tractors hydraulics on the left side under the floor board. Plump the in side of loader valve to the main pressure outlet( an 90 degree male flare if I remember correctly), then plumb the out side of loader valve to the metal line that was connected to main pressure outlet. I had a 2400A hydro that I put a Davis loader on some 25 years ago. The fellow I sold it to still uses it.
Les Chapel
04-01-2005 05:50:22
 Thanks in reply to geok, 03-31-2005 19:42:48
Thanks for the info, this should be very helpful...Les
Joe Bloggs
03-31-2005 07:38:39
 I would like to know also in reply to Les Chapel, 03-31-2005 06:59:44
I would like to know this as well for future reference
