Tractor Talk Discussion Forum
Toe ?
Tim (ny)
03-31-2005 10:43:44
What's the correct toe setting for a wide front end tractor? Its an Allis D-17, if that matters. Thanks.
Brian G. NY
03-31-2005 16:33:50
 Re: Toe ? in reply to Tim (ny), 03-31-2005 10:43:44
Hi Tim, The WD-45 manual calls for 0-1/8" toe in. This is the first time I looked it up; when I replaced a tie rod on my WD-45 I set the toe-in at 1/4". Seems to work OK. I always make sure I spread the front of the wheels apart as much as I can when I set toe-in to compensate for any wear in the steering parts.
tim(ny)
04-01-2005 07:30:08
 Re: Toe ? in reply to Brian G. NY, 03-31-2005 16:33:50
Thanks, Brian.
