Tractor Talk Discussion Forum
OT-Light Bulb of an Idea!!!
Dug
03-31-2005 14:38:59
The ignition problem has been diagnosed as a broken "actuator". My mechanic (who knows my mechanical and electrical capabilities pretty well) strongly advised against my undertaking of this project. So on to the next phase of "correcting the problem".
What if, and this is a big "what if", I wire directly into the starter soleniod with a push button mounted in the cab of the pick-it-up truck? Seems like it should work. I can start it now by turning the key on, popping the hood and jumping it with a screwdriver, sooooo am I crazy to be thinking this? What potential harm am I looking at? Is this exceptionally hard on the starter solenoid? What size wire would you recommend?
Thanks,
Dug
ChrisH(IA)
04-01-2005 05:05:35
 Re: OT-Light Bulb of an Idea!!! in reply to Dug, 03-31-2005 14:38:59
Hello Dug--In my Ford, the actuator controls all of the ignition. When it broke, turning the key didn't energize any of it. The actuator is a diecast piece that runs down the side of the column to a little electric switch that has off, on and start positions ("on" to "start" spring loaded). I dismantled the column cover to get to that switch and use a nail set to start it. (was told by Ford dealers that they don't stock that part) My point is that maybe your actuator rod isn't really broken. Good Luck ChrisH(IA)
Willy-N
03-31-2005 19:45:14
No biggy just run a 14 ga wire to the starter. Had to do the same thing to my 85 Chevy Truck. Used the button for years that way. Never did figure why the switch would not turn all the way to start and putting in a starter button was so much easier & cheaper of a way to fix it. PS I also fixed it the day it broke needed to drive the truck. Just make sure the wire going to the solonoid is making a good conection befor you put a button in. That could also be your problem. Mark H.
Super Steve
03-31-2005 16:40:16
My dad had an 88 gmc farm truck that started like that. somethig in the steering column got messed up and would not turn past the run position so him and a friend wired it up with a push button. worked good. still was working when the truck got shipped to the wrecker. Steve
Redmud
03-31-2005 16:01:31
Dug, your not crazy, that will work as long as the key will turn on the ign. could last forever.
Dug
03-31-2005 16:14:45
 Re: OT-Light Bulb of an Idea!!! in reply to Redmud, 03-31-2005 16:01:31
The key turns the ingnition on, just will not engage the starter.
Any suggestions on gauge of wire I should use?
Dug
Mike M
03-31-2005 16:41:32
 Re: OT-Light Bulb of an Idea!!! in reply to Dug, 03-31-2005 16:14:45
I would look at what is on there now and go with at least that size maybe one size bigger.
Redmud
03-31-2005 16:39:59
14 gauge will do fine. and run your hot wire from the fuse panel to your button, then from button to solnoid.
Herschel
03-31-2005 16:50:42
 Re: OT-Light Bulb of an Idea!!! in reply to Redmud, 03-31-2005 16:39:59
You need to remember that by going direct to the starter you are bypassing all safety switchs. Which means that if you have an automatic transmission the starter will run when you push the button no matter what gear it is in.
Redmud
03-31-2005 17:08:12
 Re: OT-Light Bulb of an Idea!!! in reply to Herschel, 03-31-2005 16:50:42
Herschel, thats true, but how many times do you park your truck with it in gear? it just comes natural to stick it in park rat before you turn the key off.
Herschel
04-01-2005 17:02:47
 Re: OT-Light Bulb of an Idea!!! in reply to Redmud, 03-31-2005 17:08:12
Redmud,How many times do you not put it in park? It only takes once. And you might not be the only who drives it.
