Tractor Talk Discussion Forum
Center of Gravity--Help!
Allan in NE
04-02-2005 01:27:38
Mornin' Guys,
Okay, as I've stated before, I'm just not too darned bright and I come here to learn from you folks. Now, I’m running into a little situation where I could use your collective knowledge and insight, 'cause I guess Mom didn't learn me good. :>)
Farmed forever with tractors A and B. Went broke and sold out. Now, while having silly aspirations to get back all of my lost toys, I buy tractors C and D to replace my old ones. Fine. So far, so good.
Tractors C and D are identical in every way to the old tractors A and B except for the darned rear tire sizes. Old ones had 16.9 x 38 tires and the new tractors have 18.4 x 38. Also, new tractors both have fluid, the old ones did not.
Now, when I hook up the very same identical 3-point equipment to these tractors and on absolutely level ground, I’ve got a light front-end issue going on that I never used to have before.
The first time I noticed it, was when I bought a little rotary mower; seemed like that little feller was awfully darned heavy back there for some reason. :>(
Everything is the same except the tire sizes and the fluid and the difference between the tractors has reached something of a safety threshold around here. Ya can’t control the tractor with the front end swingin’ up in the air all the time. Plus, it’s gotta be kinda hard on brakes. :>)
Anyway, how can the larger diameter of those rear tires move the center of gravity rearward so darned much? It would seem like it should be the other way around, shouldn’t it?
Or is it just simply the torque of the larger tires vs the torque of the smaller diameter tires that is causing my headaches?
Yes, I know the cure is to add weight to the front end of both tractors and I’m in the process of doing just that. But, I’d just like to understand the “why” of the thing?? :>(
Thanks for instructing an old dog,
Allan
Dixieland
04-03-2005 06:59:57
 Re: Center of Gravity--Help! in reply to Allan in NE, 04-02-2005 01:27:38
Old feller told me "Don't worry about the horses, jest load the wagon". That was ok by me but guess who had to unload it? Sometimes I wonder what the engineering department was doing not figuring all this out ahead of time. You caint sell out of an empty wagon and besides, what did they think a farmer was gonna do with the dang thang if it could'nt be used to pull???Live and learn, die and fergit it all!
Nuther Tare Question?
04-02-2005 08:26:57
Are you sure you want me to go there?
Dug
Allan in NE
04-02-2005 09:18:34
 Re: Center of Gravity--Help! in reply to Nuther Tare Question?, 04-02-2005 08:26:57
Yes, you're right.
I would imagine that this phenomenon only pertains to red tractors as I've heard tell the greeners just break in two pulling this type of equipment.
Mornin' Dug! :>)
Allan
Dug
04-02-2005 18:27:44
 Re: Center of Gravity--Help! in reply to Allan in NE, 04-02-2005 09:18:34
Eeewwww, that one stung! Everyone knows Johns don't break, that picture was altered.
Awrite, that tire and balance thing has to do with the geophysical sub-balance of the "S" tire with too much air pressure causing an inner instability, thus the seemingly unstable front end. Interestingly enough, what appears to be a "light" front end is actually the the environmental effects of previously said circustance. To properly correct this situation, check your tire pressure in the "S" tire.
That's all for tonite,
Dug
billyiron
04-02-2005 07:03:27
the same thin western nebraska air that affects Allans thinking process has somehow also affected the gravitational pull on IH tractors,This is just a temporary thing that will pass as soon as his wife smacks him in the head with the fry pan,,,then he will be back between the ditches ,,,untill the next relapse,,,billy
Sloroll
04-02-2005 06:32:03
You went from a fairly active job to one of computing skills about twenty years ago..... Did you cut back on donut consuption? Do your jeans seem smaller? Tractor's seat too? The seat is still located ruoghly over the rear axel right? Dunno :? )
Allan in NE
04-02-2005 07:08:04
 Re: Center of Gravity--Help! in reply to Sloroll, 04-02-2005 06:32:03
Oooops!
And I've been chewin' out the wife for washin' the jeans in hotter and hotter water because they seemed to be shrinkin' mor and more every year. :>(
You're tryin' to tell me that it isn't all her fault? :>)
Allan
Joel Harman
04-02-2005 05:38:13
If you were talking an airplane I would tell you to move your heavier rear wheels towards the front of the tractor.
you have changed your fulcrum point with larger rear tires.
It could work to shorten arms on 3 pt, but bet you will just ad weight on front end?
Allan in NE
04-02-2005 07:13:23
 Re: Center of Gravity--Help! in reply to Joel Harman, 04-02-2005 05:38:13
Yes Sir,
Got one set located and am diggin' in every scrap pile I can find to locate the second set.
Trouble is, now I don't have anywhere near the physical strength I used to have, so I'll have to be sure and take the wife along so she can load 'em in the pickup for me. :>)
Thanks,
Allan
Indydirtfarmer
04-02-2005 05:14:44
Allan,
After applying much thought to your problem, it hit me a few minutes ago just what the problem is. It was so simple, I don't know why it didn't occurr sooner!
It's your wallet!
Years ago, when you were a full-time farmer, that wallet was thin and light. As it rested in your back pocket, it applied no weight to the rear of the tractor, and didn't effect the tractors center of gravity.
Fast forward to present day Allan.....
Nowdays that overstuffed mattress of a billfold is riding heavy out over the rear wheels, totally wiping out any sense of balance that was previously there.
Solution????
Put your wallet, along with the millions of pesos contained within on the front weight bracket. At that point, you will be able to safely lift the entire capacity of your tractors 3-point hitch WITHOUT SO MUCH AS A THOUGHT of raising the front end off the ground.
SEE! I knew we could straighten this out.
Your pal,
John
RustyFarmall
04-02-2005 05:39:41
 Re: Center of Gravity--Help! in reply to Indydirtfarmer, 04-02-2005 05:14:44
Indy, and the moral of this story? Farming with IH red = fat wallet. Farming with JD green = thin wallet. LOL
Indydirtfarmer
04-02-2005 05:49:28
 Re: Center of Gravity--Help! in reply to RustyFarmall, 04-02-2005 05:39:41
OR.....Sell the farm, start a rather successful internet business, buy TONS of IH tractors/implements at reduced prices, then leave the REAL farming to us with REAL farm equipment, then ask a lot of questions.
Paul in Mich
04-02-2005 04:40:48
Allan, Im not talking from an experts standpoint, but from some experience. You may have 2 factors at work here. First having loaded rear tires could influence the handling and steering, and the wider width can also have an influence. The reason I say this is that we have two 966"s, equipped with dual rears. and while they both have the same size rear tires, the outside duals are set at different widths. The Tractor with the wider span is harder to handle and steer, and requires more braking to make turns. Even with suitcase weights mounted in front, I"ve noticed that soft headlands require as much foot steering (braking) as turning the front wheels, especially with the wider configuration. As to the real center of gravity issue, I have discovered that at age 65 my center of gravity is much more profound than when I was 35. It takes a lot more strength to climb on the tractors, and once there, requires more cushion than the factory seats provide. It seems that every year that seat gets harder and harder.
Mike M
04-02-2005 04:21:12
I thought you were a Farmall guy ? Your problem appears to be that tractor model D. You should of stopped with A,B&C.
Coloken
04-02-2005 03:50:08
Like Jim asks, are the arms longer? This would be a large change. My thoughs are that it is an "apearant" diference. The fluid can cause an enertia when you let out on the clutch and you get a feeling of the front end comeing up. Yes, age makes us notice safty thing a lot quicker than we used to.
Vern-MI
04-02-2005 04:11:31
 Re: Center of Gravity--Help! in reply to Coloken, 04-02-2005 03:50:08
Ken is right on. The rear wheel mass is at rest when you start to move or change speed it doesn't want to move or change speed. The tractor wants to rotate around the mass in the rear wheels. To test the theory just exagerate the condition and consider what would happen if you attached ten more fluid filled tires to each side in the rear. The tractor couldn't move forward but instead it would rotate around the rear axle.
Allan in NE
04-02-2005 07:03:39
 Re: Center of Gravity--Help! in reply to Vern-MI, 04-02-2005 04:11:31
Mornin' Vern,
I thought it was something along that order.
And, come to think of it, this past week is the very first time ever that I've operated a loaded 3-point while at the same time on a set of loaded tires too.
Objects at rest tend to remain at rest or something like that? Those rear jokers have a lot of weight to 'em and what you say just makes sense.
Also, like Joel says, the derned tractors stand taller now too than they did with the 16.9s, that's just a fact.
I know people think I'm a little wacko, but I can certainly remember the front ends getting a somewhat "feather feel" to 'em, but I sure don't recall those old irons rearin' three feet in the air with every clutch release and every time I took off from a dead stop either.
Thanks Guy, I appreciate it,
Allan
Tx Jim
04-02-2005 03:33:04
 length of 3pt lower arms in reply to Allan in NE, 04-02-2005 01:27:38
Allen I think 3pt arms are longer on tractors/ larger tires to move implement from tires.This would move implements back further.Of course your IHC"s could have aluminum front ends!!He-He Tx Jim
Hugh MacKay
04-02-2005 03:01:31
Allan: The key to the whole problem may lie in the last line of your post, "old dog". As I recall you and I are not a lot difference in age. As we get older we want comfort in everything we do. These daring things we did 20, 30, 40 and even 50 years ago, are no longer acceptable.
There is a comedian near here writes a short article in one of our farm papers. His description of this age and comfort item, is as we age we want comfort in every thing we do and have. He listed about 25 items, thus I will miss a few. Our chair we most commonly use must be comfortable, car must be comfortable, bank account must be at a comfortable level, our toys must be comfortable and even in encounters with your good better half comfort becomes more important than passion. That is just a few but you get the idea.
I assure you, your not the only one in this boat, age plays funny tricks on you. For example, I have a brother in law, 65 years old. Was a bureaucrat all his working years, has so much money he is afraid to die, thinks his boys may have too much fun with the money. He and his good wife have become health food nuts. They have so many pills, suplements and careful about what they eat. Would drive anyone right up the wall. Problem is they can't remember which pill they took and when.
Trust me you are in pretty good shape.
Allan in NE
04-02-2005 07:28:14
 Re: Center of Gravity--Help! in reply to Hugh MacKay, 04-02-2005 03:01:31
Oh,
I know I'm definitely creepin' up in years Hugh, but I still have my faculties about me.
There is darned sure a difference going on here and I think it must have to do with the fluid in the tires like Vern said.
Rode the old heifers too blamed many years not to notice something like this. :>)
Thanks,
Allan
thurlow
04-02-2005 04:56:22
I think Hugh has it right on; would suggest also that your whole focus/reason for having/driving tractors has changed. Have also noticed that my perception (of almost everything) has changed..... my interest in most things is pretty much the way it's always been; my passion for them is much less.
steveormary
04-02-2005 21:15:02
 Re: Center of Gravity--Help! in reply to thurlow, 04-02-2005 04:56:22
Allan;
What you need to do Allan is check the ampacity of the tractor and the implement to make sure they balance out. Otherwise your front end will get light and make it hard to steer.
Almost fergot. You will need and ampacity checker for that and I believe right now they are out of stock.
steveormary
Ken Macfarlane
04-04-2005 06:22:39
 Re: Center of Gravity--Help! in reply to steveormary, 04-02-2005 21:15:02
The tires don't affect the centre of gravity. They do affect the little transient when you start but I doubt your tractor has top-fuel like acceleration.
Re the dual spacing and turning, of course it is harder to turn. The wider the tire (or spacing or duals) the more scrub they have when turning. More scrub equals more weight needs on the steer tire or more braking.
