Tractor Talk Discussion Forum
Ford 5640
TimH
04-04-2005 08:45:56
I have a Ford 560 with 4500 hours. The tractor will no longer shift into Forward gears although reverse and neutral work. One individual has told that probably a "synchro" gear for the Forward / Reverse has gone bad and that this can be replaced from the front of the transmission if I break the tractor. Can anyone comment on this. I have tried adjusting the shifting linkage with no results.
Also, I"m looking for a repair manual for the same tractor...any suggestions as to where to get one?
RickB
04-04-2005 15:49:20
 Re: Ford 5640 in reply to TimH, 04-04-2005 08:45:56
Go to a New Holland dealer or their website and get an original repair manual. Depends on what transmission you have as to how much is involved. S. SL, and SLE models have different gearboxes. You must have an SL or SLE to have a F/R synchronizer, and I don't know if they offered the 56 as an SLE. I did an F/R synchro on an 8240SLE and don't know if that repair can be made with a front split only. The manual does not suggest that it can, and I was not going to experiment on my first time in one. I re-sealed all four clutchpacks and repalced most all of the "soft" parts in that one as it had 6000 hrs.
