Tractor Talk Discussion Forum
John Deere 112 Garden Tractor variable spd
Earl H
04-04-2005 10:21:44
Can someone tell how to adjust the variable spd on a 112 John Deere garden tractor. The variable speed will not work in the first two notches of the variable speed in any gear.
Maark
04-04-2005 18:14:28
 Re: John Deere 112 Garden Tractor variable spd in reply to Earl H, 04-04-2005 10:21:44
With the engine running, place the variable speed lever in the 5th notch, below that is a snap in plug. Remove it, you will find a bolt head that takes a 3/4" socket, loosen that bolt and pull up on the clutch pedal. Then tighten the bolt.
Coloken
04-04-2005 16:16:10
Go to the JD garden tractor place..I think its a yahoo hoby group. Or get the operators manual.There is a very difinite way to adjust it just right. They tend to wear and get sticky. See if you can work some lub down into where the pulleys slide. I helped mine by adding an extra spring. You have to take the fenders off to see what I am refering to.
Kenny
buickanddeere
04-04-2005 12:17:43
Deere has an excellent operators,parts and service manual all in one book. Call 1-800-522-7448 with the tractor's serial number. The proper set-up of these take some precise steps and settings. Is the transaxle in the front or rear position?
earlschieb
04-04-2005 10:44:48
Does it need a a new drive belt?
