Tractor Talk Discussion Forum
Removing calcium chloride from tires
David Lewis
04-04-2005 19:38:44
Bought a nice 1954 Fordson Major diesel, but it leaves deep ruts on the lawn and wife is frowning at me. Guess what - it has CC in the rear tires. If I empty them out I will lose 600lbs which will help.
I am more concerned about the long term corrosion effect of CC on the rims - if I drain the stuff out, will corrosion happen faster than if I just leave it in there and put up with glaring wife for a few more years? Advice appreciated - thanks.
Leroy
04-06-2005 04:23:26
 Re: Removing calcium chloride from tires in reply to David Lewis, 04-04-2005 19:38:44
If close enough to get would love to have your CC
MSD
04-05-2005 20:46:23
Turn the wheel so the valve stem is on top. Let the air pressure out and then slip a small hose over the valve stem. Turn the tire so the valve stem is on the down side or there abouts and the fluid will drain out nice and slow. When your bucket is full, turn the tire so the valve stem is up and it will stop flowing.
Dave Sherburne,NY
04-05-2005 18:12:10
tire guy I deal with will take it out for nothing if I give it to him.
wayne2
04-04-2005 20:59:38
David, I have 430 case tug, after couple years of parades drained cc, 5 years laterno appreciable damage other than what was present. (do not squirt cc on plants or towards, stream went 15-18 ft, killed grass and a nice wirsteria vine) OOOPS!!
tire_guy
04-05-2005 17:31:19
 Re: Removing calcium chloride from tires in reply to wayne2, 04-04-2005 20:59:38
Draning the calcium from the tires won't make any diffence in how fast the wheel corrodes. If it has had a leak in the past and wasn't cleaned up good before it went together, it will rust out. If the calcium hasn't ever touched the rim then it won't rust. As was said when you pull the plug the calcuim will shoot a really good stream so watch where it is pointed and the wind. You can slip a small hose over the end of the valve stem after you pull the plug to control the flow but it is messy and you will probably take a bath in it. Also be sure to rinse everything off with fresh water when done.
