Tractor Talk Discussion Forum
Specs. on tach or speedo cables?
jdemaris
04-04-2005 20:11:54
I'm looking for a mechanical tachometer cable for a Case 580CK backoe. I put a newer 207D engine in it, so I'm not sure the standard cable would fit even if is was available. Looks to have standard fittings and I suspect there are many ready-made cables available that would fit. Problem is, I've been unable to find anyone that sells cables, that can give me specs - including this Site. I called and they don't have any specs other than lengths. None of the local dealers stock cables so I can't look to check for fit. So, if anyone has a source for specs, please advise. The cable I need can be 54 to 64 inches long. Tach. end of cable needs a 5/8" X 18 nut with square drive cable end (standard 7/64"), and drive end of cable needs a 7/8" X 18 nut with a tang drive (standard 5/32" pin with tang). I know many tractors, as well as cars and trucks have used this same configuration. This site shows an Oliver cable that looks right and is 60", but I don't know what the ends are. Deere uses the correct lengh cable on the 420-430 series (AM3131T), but again I'm not sure what the ends are.
barryinmn
04-05-2005 19:21:36
 Re: Specs. on tach or speedo cables? in reply to jdemaris, 04-04-2005 20:11:54
Maybe these guys can help - I'll be taking my Allis Chalmers 615 tach hour meter to them whenever I get around to taking it out!
MERCEDES speedometer & instrument repair, restoration, 24 hour service on most repairs. APT Instruments, 9632 Humboldt Ave S, Bloomington, MN 55431, PH: 952-881-7095; email: demaree@uslink.net; web: www.gaugeguys.com and www.tachshack.com Category:
Mike M
04-05-2005 05:24:00
Go to your local semi truck repair/parts dealer or shop. I used to work at a Navisar dealer and we had a kit full of parts to make up cables and even speed reducers and increasers.
Easy
04-04-2005 22:11:04
There is a guy here in SE Michigan that makes up cables. I can get his name and business # if you want. I forget the name, but he is in Redford, been there forever. Easy.
Ken Biggs
04-05-2005 07:40:29
 Re: Specs. on tach or speedo cables? in reply to Easy, 04-04-2005 22:11:04
Easy, Would appreciate also if you coould give me the name and address of the guy who supplies inner and outer cables for speed/tach gauges etc, need one for hour meter and revs on my Moline , 1957 model.Need also the hour and rev gauge head, The engine end is just a screw-on nut outer cable and the regular square fitting end inner cable.
Thanks for help, Ken Biggs Kentucky.
Easy
04-04-2005 22:12:30
I will email ya in morning. Easy.
