Tractor Talk Discussion Forum
Compacts: JD 4120/4310 versus Case IH DX 40 (TC40)
Ben Held
04-06-2005 07:37:18
Trying to decide between a JD 4120 HST and a Case IH DX 40 HST (same as NH TC40 I think). The 4120 has 3 more hp, but similarly equipped is about $3k more than the DX40. Both are good dealers - the case dealer is about 10 miles from my house, the JD dealer about 35 miles.
Advantages that I see in the JD (please comment on these):
1. Load Match - is this a big deal?
2. Slightly higher hydraulic output (17 gpm vs 14)
3. Slightly larger loader capacity
4. Better reputation?
5. More likely to have parts available longer
6. Speed match
Advantages to the Case DX40:
1. Swivel seat
2. Price
3. Better loader joystick
4. High/low HST button right on joystick
Thoughts? This machine will be used for loader work, box blade for long driveway and with 6' bushog for mowing about 15 acres.
paul
04-06-2005 08:11:22
 Re: Compacts: JD 4120/4310 versus Case IH DX 40 (T in reply to Ben Held, 04-06-2005 07:37:18
www.tractorbynet.com is a good place for compact tractor discussions.
Me, I hate the hydro trannies (steal power & reduce feed-back to the operator...) & plastic & electronic new tractors. You'll find a lot of that 'tude from around here. :)
I really like my NH 1720 tho - nice manual shift, not too much plastic yet.... The things you mention as good features sound like future nightmares to me, but I'm used to putting 1000 hours a year on my various tractors & need to keep them running without spending $95 an hour for labor. So, the less flash & plastic, the better....
I think in the end, it is your coin flip on those 2 - it will come down to the money & which one feels better to your back side... Not much of any other difference. Both engines come from good Japaneese stock, and the rest is all just bolted on stuff of about equal value.
If it were me, I would be comparing the loader lift capacity to the extra money to make my choice as those are the only 2 things I see of value in your list, but that is what would be important to _me_. You need to sort out the fine points of what is important to you. Is the hyd output something you will need/ use - the gpm is actually pretty close in the same range - but if you have a _need_ then it could be important???? Are you getting extra ports on the tractor? You need to define how you are going to use your tool, & buy the tool that does the things you need. And so on.
--->Paul
