Tractor Talk Discussion Forum
gauging haybine prices
old fashioned f
04-06-2005 07:47:22
Howdy folks,
Well, as I shift some of my farming ideologies from playing around with old equipment to actually trying to pull down a few dollars so I can buy fuel for the equipment I'm playing with, I've decided to look for a haybine to replace my old sickle mower. The biggest reason is that for the last 3 years I've put up alfalfa stems instead of alfalfa hay. The weather here in S. Ohio has not allowed time enough for the hay to cure when I sickle cut it. My neighbor came down to his field next to the house and put up a beautiful crop with his haybine doing the cutting. In my field, as the hay laid for days curing, a nice shower would pop up and ruin another cutting. I even borrowed that neighbor's tedder to help but those darn stems were the factor stopping me. I pushed my luck last year on the third cutting and baled a little early to save leaves but I ended up selling the last part of that cutting for $1 a bale due to the mold it had acquired from having moist stems. It was dry but the stems were not. So the question is, what kind of prices do these haybines have? I did price one in Hillsboro, OH last week while on a trip to a sale. It was 7' cut and $3500. What kind of prices do you all know of for used haybines? 7' would be the best due to gate limitations and storage space. I appreciate the help. God bless.
--old fashioned farmer
ChrisL
04-06-2005 08:53:33
 off topic in reply to old fashioned farmer, 04-06-2005 07:47:22
just a hint if you stick with your sickle mower -
cut it a week earlier and the stems won't be nearly as large - and if u cut it a week earlier three times a year u may get an extra cutting anyway
also - i am starting to believe the only real good way to do first cutting hay is with a silage cutter -
Buckeye
04-06-2005 09:19:38
 Re: off topic in reply to ChrisL, 04-06-2005 08:53:33
We've been a month late getting the first cutting up here in Southern Ohio the last two years due to rain! Fields were just to wet to get on and hay would not dry on damp ground either. I raise about 300 acres of hay and two years ago it was so bad that I still had some first cutting to mow/bale the first of September! I should be done by the first of July. Hope we have a good year this year!
