Tractor Talk Discussion Forum
3400 Ford Diesel quit running
Nick in VA
04-06-2005 20:00:15
Parked my 3400 Diesel tractor the other day just fine. Started right up today but only ran a few seconds. After much cranking it fired up but would "shudder" or "stumble" while it was at idle. After 10-15 minutes it slowed down and gradually shut off. All obvious stuff-plenty of fuel, hot battery seems fine. Tractor is 70's vintage. Any suggestions? Thanks in advance. Nick in VA.
grouch
04-06-2005 21:14:43
 Re: 3400 Ford Diesel quit running in reply to Nick in VA, 04-06-2005 20:00:15
Air or water in the fuel lines or injectors? Clogged fuel or air filter? Diesel only needs compression + air + fuel, at the right time and in the right amount.
Allan in NE
04-07-2005 06:04:03
 Re: 3400 Ford Diesel quit running in reply to grouch, 04-06-2005 21:14:43
I agree with Grouch,
Your symptoms (especially that "slowin' down" part) are screamin' that you've run out of fuel.
Check your fuel filters?
Allan
