Tractor Talk Discussion Forum
What do you use for a tool box on a tractor withou
Doyle Alley
04-08-2005 13:01:36
Many of the "old iron" machines came with nice attached tool boxes to hold things that would be frequently needed in the field. My JD 950 doesn't have one, and I'm frequently having to trott back to the truck for a wrench or lynch pin or whatever. I'd like to try and attach something. Can anyone give me examples of boxes that have worked for them and how they've attached them?
cannonball
04-09-2005 07:01:01
 Re: What do you use for a tool box on a tractor wi in reply to Doyle Alley, 04-08-2005 13:01:36
on tractor without loaders, i put a heavy piece of angle where the loaders bolt..i built a box and weld it to the angle..build a heavy locking sys...oh yes these are deeres, don't know about others...built one for a 401b got ready to mount it and looked and realized oh no swept back front end, had to angle the front part of box...have nice day may god bless
msb
04-08-2005 19:48:34
 Whatever happened to the step toolbox in reply to Doyle Alley, 04-08-2005 13:01:36
Used to buy those diamond tread step tooxboxes for about $50,that were easily taken off the tractor when parked at night in a vulnerable location.Should have listened to myself last year,just by pulling and turning 2 latches.Someone got a real nice set of tools that belonged to me and a newly painted tool box.Anyway I have looked high and low and can't seem to find a new one.The manufacturer found ways to keep making them cheaper and cheaper.No wonder they quit making them.
Dixieland
04-08-2005 18:44:21
Ammo box works great...keeps everthing dry...you can find um at flea markets...mine is mounted to the frame.
Ron in AR
04-08-2005 16:49:07
I do it cheap and easy. Fasten a milk crate to the back of the seat with bungee cords and put a small box inside so the smaller stuff doesn't fall out. Plenty of room for my water jug and any other tools and stuff I want/need to carry.
JiminIA
04-08-2005 14:33:43
I make an angle iron frame to hold a standard toolbox. That way I can have a box for each implement and switch it between tractors...Jim
John (MO)
04-08-2005 14:21:36
I found a tractor tool box with a mounting bracket that allows you to pull a pin and take the whole box off, it was $10.99 from value built.
Steve(OR)
04-08-2005 14:14:05
How about an ammo box attached to a fender.
Fawteen
04-08-2005 17:39:14
 Re: What do you use for a tool box on a tractor wi in reply to Steve(OR), 04-08-2005 14:14:05
Bingo. I have an ammo box clamped to the ROPS just above the fender. Piece of bar stock on the back side, two long bolts, coupla big fender washers and nuts inside the box. Wrapped a couple wraps of inner tube around the ROPS post to keep it from rattling and/or moving around. Works like a champ, keeps the tools dry, a squirt of WD40 every coupla years keeps 'em from rusting.
Not a lot of tools, but extra linch pins, hairpins, hydraulic swivel couplers, stuff like that.
