Tractor Talk Discussion Forum
hydraulics question
Rance
04-09-2005 09:29:06
The other day a hydraulic line on my backhoe snapped off at the base of the threads where it entered the fitting on the cylinder. This was a hard line, not a flexible hose. My question is can I replace that with regular 1/2" iron plumbing pipe or do I need a special high pressure pipe?
Thanks
mj
04-09-2005 23:40:11
 Re: hydraulics question in reply to Rance, 04-09-2005 09:29:06
'Old' is right. Also, Surplus Center and Northern Hydraulics have a variety of fittings.
old
04-09-2005 11:19:22
Yes and no normal pipe will work but you will not get good service from it because it will brake in a short time. But if you get what is called S80 pipe which is the heaver duty water pipe that works very well.
