Tractor Talk Discussion Forum
1950 or 1951 Super A Farmall
danny clark
04-09-2005 10:33:25
Can anyone give me some info about a1950 or1951 Farmall Super A? This tractor would run on gasoline or kerosene.
Paul in Mich
04-09-2005 19:29:51
 Re: 1950 or 1951 Super A Farmall in reply to danny clark, 04-09-2005 10:33:25
Danny, By 1950, Distillate models were all but obsolete, however there were a few Kerosene models still being built. Distillate fuel was most popular during WWII as it was a low grade fuel, cheap, and more plentiful than gasolene. If your tractor was originally a distillate, it would have been designated by the serial number which would have had the prefix of FAA****** with no suffix. Kerosene models had a suffix of X after the numbers. Both distillate and keropsene models were equipped with auxillary fuel tanks so they could be started on gasolene then switched manually to the low grade kerosene or distillate when the engine warmed up enough to give those fuels good combustion. They also were equipped with radiator shutters to allow the engine to run hotter for low grade fuel. Also the manifold was designed with a damper which when closed down would enhance the atomization of low grade fuel not required with gasolene. X1 was the suffix for gasolene models. Either kerosene or distillate models will run just fine on gasolene, however, an X1 gasolene model will not run well with Kerosene or distillate as the engine wont develope enough heat to properly burn the low grade fuel. After the war, many owners of kerosene or distillate models simply filled the main fuel tank with gasolene, opened the shutters all the way, opened the manifold damper, and never burned anything but gasolene from that point on. Through the years, many of those tractors were stripped of the auxillary tanks, shutters, and in particular shutter linkage, and as manifolds needed replaced, installed gasolene (conventional) manifolds. I presently own a 1940 Distillate model A, and with the exception of the manifild, has all the other dual fuel components, but I burn strictly gasolene. The extra goodies as I call them are there for looks only. While your Super A may or may not be a low grade or dual fuel tractor, it too will function fine with gasolene.
Hugh MacKay
04-09-2005 14:37:53
danny: The Super A will certainly burn gasoline, it could also be equiped fot burning kerosene. I have never had anything to do with kerosene burners. I know they require extra equipment. They were also able to burn a product called distillate, which also required extra equipment. Whether the extra equipment for kerosene and distillate were exactly same I'm not sure.
My dad had a W4 that was equiped for one or the other or both. It had small, probably 1 gallon fuel tank under hood just in front of regular tank, that was use for gas for starting. The tractor also had shutters in front of radiator. There was also a shield around carb to deflect heat from manifold. I was only 9 when they traded W4 off for an H in 51. I don't remember them using kerosene or distillate, but understand they did during WW#2. A Super A would need all the same items.
There are numerous guys on here with kerosene and distillate experience. CNKS is the first guy that comes to mind. Sorry but I'm just not absolutely sure I'm exactly right on all of this.
These guys see activity on this they will jump in, if not go to the IH page, you will find someone that knows.
Dave H (MI)
04-09-2005 11:04:11
There's a guy named McKay over on the International forum knows a lot about these. I think he posts here too. He'll be along if you wait long enough. Just don't give him any clues as to where you live or you may just have a Buick with Canadian plates in your driveway next weekend. :-)
Hugh MacKay
04-09-2005 14:42:27
 Re: 1950 or 1951 Super A Farmall in reply to Dave H (MI), 04-09-2005 11:04:11
Dave: Come to think of it, I must have been quite close to your drivway last Sunday. Drove from Detroit to Flint on I-75.
