Tractor Talk Discussion Forum
70 flywheel
2 popper
04-11-2005 06:19:58
I need the weight of a 70 flywheel with the starter ring still on.
Thanks.
old joe in Michigan
04-11-2005 16:33:12
 Re: 70 flywheel in reply to 2 popper, 04-11-2005 06:19:58
HI 2 popper,
I just happened to have my JD 70 gas fly wheel still off as I am rebuilding the engine, so I went out to barn and weighed it for you.
It is a taper lock # F1226R made by Allen foundry works. It weighs 153lbs including the taper lock nut and collet and it has the starter ring gear on it.
Hope this helps
old joe Michigan
