Tractor Talk Discussion Forum
656 wide front end info
marcus19992
04-12-2005 07:31:04
hi,i have a 656 utility tractor.unlike ones i have seen this one has a factory wide front end that sets back about a foot or foot and a half further back under the front of the tractor.was it built for county and state uses or? any info would be great.. thanks..
Hugh MacKay
04-12-2005 08:31:14
 Re: 656 wide front end info in reply to marcus19992, 04-12-2005 07:31:04
marcus: From your description, I think you have the standard axle for a Utility. It is a swept back axle, giving the tractor shorter wheel base. All Utilities have a wide front end as they came from factory.
marcus19992
04-12-2005 08:59:25
 Re: 656 wide front end info in reply to Hugh MacKay, 04-12-2005 08:31:14
thanks hugh,i"ve seen a few 656"s with a wide front similar to the ones seen on a 706,806 etc where the front end is below the cradle. this one was unique and i had to find out a littlew more again thanks
Hugh MacKay
04-12-2005 15:28:57
 Re: 656 wide front end info in reply to marcus19992, 04-12-2005 08:59:25
marcus: the model you saw with axle like 706 or 806 would actually be the Farmall 656, called the row crop model. The utilities are set somewhat closer to the ground.
