Tractor Talk Discussion Forum
Air Filter for 1947 Ford 8N
Sean O.
04-14-2005 16:13:31
I have a 8N. Bought with no existing air filter system. I just purchased a new filter system from YTG tractors. It is about size of small fire extinguisher and has a cup on bottom that says oil level. Question is, what goes in this thing as I don't have an old on to go off of and manual doesn't say????? HELP !!!!! !
Nolan
04-15-2005 04:12:18
 Re: Air Filter for 1947 Ford 8N in reply to Sean O., 04-14-2005 16:13:31
It might help you to understand how that filter works.
Up inside that fire extinguisher sized can is a mesh of metal that looks a lot like a metal dish scritchie thing you'd find in the kitchen. As soon as the engine starts and begins pulling air, it sucks up the oil onto that metal mesh. Air only goes percolating through the pool of oil on startup. As soon as it's pulled up onto the mesh, the level in the cup is dropped, and air flows over it instead.
Now the air is flowing through that oil coated mesh, and the dirt gets stuck on the oil. Sounds just like a K&N filter, doesn't it? It's the same method of filtering.
When you turn the tractor off, the dirty oil drips off the mesh down into the cup. The dirt settles to the bottom, and relatively clean oil is sucked up onto the mesh the next time you start the engine.
The dirt that settles down into the bottom of the cup is why you need to clean it out occassionally.
Some oil does get sucked off the mesh and into the engine. That's why the oil level goes down gradually.
Ford recommended engine oil for the oil bath filter. That works just fine. A true filter oil (which is stickier) works better and costs a whole lot more, but really is unnecessary.
Don't put something like gear oil in there, as it's too viscous to get drawn up into the mesh, and your tractor may well not start as it can't draw air through the pool of heavy oil sitting in the cup.
Coldiron
04-14-2005 17:28:22
Sean, Add a good clean lubrication oil to the cup and reinstall it. You will need to keep the debris and muck that will settle in the bottom of the cup cleaned out. Replace it with clean oil. Be sure to fill it to the OIL LEVEL mark. It will be sucked up a bit into the media or screen in the top portion to give it a coating of oil that dust/debris will cling to and be washed down into the cup when the engine is off.
Sean O.
04-14-2005 18:12:48
 Re: Air Filter for 1947 Ford 8N in reply to Coldiron, 04-14-2005 17:28:22
Not the most mechanically inclined. This is our first tractor. What EXACTLLLY is lubrication oil? If you could give some examples, name brands, weights, how ever it is that I will find it.
I am assuming that this is a liquid oil not a paste type oil. Is this correct. thanks
Coldiron
04-14-2005 18:18:42
 Re: Air Filter for 1947 Ford 8N in reply to Sean O., 04-14-2005 18:12:48
Sean, Just what ever you use in you car engine. If you have some 10w-40w that would be great. 30w would work too.
Sean O.
04-14-2005 18:34:39
 Re: Air Filter for 1947 Ford 8N in reply to Coldiron, 04-14-2005 18:18:42
Thanks that will work!!
How often should I check or change the oil and clean the cup??
Dell (WA)
04-14-2005 18:53:33
 Re: Air Filter for 1947 Ford 8N in reply to Sean O., 04-14-2005 18:34:39
Sean..... ....your Ford 8N came from the factory with a very efficent oilbath airfilter. Many tractor operations can be VERY DUSTY and will turn into grinding compound inside yer engine usless it is trapped in the oilbath. Change yer oilbath everytime you change yer engine oil, using the same oil.
Ford recommends you change yer engine oil at least once a year, in the fall. Ford also recommends checking your oilbath fill level every 10hrs (takes about 1-pint) fill both the inner and outter circles of the bath. This is ALL EXPLAINED in yer 8N Ford Owners Manual ($10, cheap and still available)..... ....respectfully, Dell
