Tractor Talk Discussion Forum
Ford 8N engine dies
Sean O.
04-16-2005 20:43:59
OK, sorry for the long post but heres what we have done and the problem still having. We did a complete tune up (new plugs, wires, cap, rotor, etc), overhauled the carb, new fuel filter and installed new exhaust manifold. Tractor starts and purs like a kitten....PROBLEM is, it runs good for about 5-10 min or so and then just dies (no sputtering or anything). Seems like it dies once it is hitting an operating temp or something....HELP ALL PLEASE. Any idea"s..... ..Sean O.
old
04-17-2005 07:46:52
 Re: Ford 8N engine dies in reply to Sean O., 04-16-2005 20:43:59
First thing I'd do is hot wire it. That takes out all the old wireing, that way you will have an idea which way to go from there. If it runs and doesn't die then its from the coil back. If it still dies its from the coil forward.
Sean O.
04-17-2005 18:18:01
 Re: Ford 8N engine dies in reply to old, 04-17-2005 07:46:52
If I was gonna hot wire it like suggested how would I do that????
old
04-17-2005 20:48:18
 Re: Ford 8N engine dies in reply to Sean O., 04-17-2005 18:18:01
Run a wire from the coil battery side to the battery. That takes out the wireing from the battery to the coil. Makes it easy to find out which side of the ignition your problem is in
pitch
04-17-2005 04:06:23
ignition switch. Yep ignition awitch that ford used was not real robust and when it gets 30 or 40 years on it a bit gunked up tha contacts have enough resistance to shut the machine down. Jumper around the swutch to test. Be careful because you will be also bypassing the neutral sfety when doing this and the tractor will start in gear and run over your ash!
RAB
04-16-2005 23:52:26
Before you do or change anything else, determine whether it is fuel or ignition related. Check for good blue spark, and for continuous flow of fuel into (by draining) the carb immediately after it stops. Check colour of plugs, perhaps, to see if it is running too weak (although not very useful indicator on an engine with only short runs like you are experiencing).
What I am saying is - work systematically to find the problem, then fix it when you know what needs fixing.
Regards, RAB
wayne2
04-16-2005 22:34:12
Condensor on model A ford did that back in 60's(Never when g-friend was with me)LOL. Sure it's simple. LOLuck
Davis in SC
04-16-2005 20:48:04
Could be condenser or coil. Or plugged vent on fuel cap, after running a while, vacuum keeps fuel from flowing ..... .
