Tractor Talk Discussion Forum
'52 Farmall Super C problems
Randy Bishop
04-18-2005 14:34:08
I have a 52 farmall super c that I cannot get to run right. It misses real bad. Sometimes when I start it, it will run fine but after it gets warmed up it will start missing. Sometimes if I choke it I can keep it running but not very well.It has new plugs, wires, points and condencer. Any help anyone?
Tommy Pierce
05-01-2005 19:15:04
 Re: '52 Farmall Super C problems in reply to Randy Bishop, 04-18-2005 14:34:08
Sounds like it is sucking air around the intake. Spark plug brands want cause that. Bad point setting will though, recheck the points.
riverbend
04-18-2005 20:11:59
I'd have a look at the coil. It should take less fuel when the engine is warm.
old
04-18-2005 15:48:14
Sounds like a fuel problem either not getting enough fuel or the carb needs to be rebuilt
kjm
04-18-2005 18:50:53
 Re: '52 Farmall Super C problems in reply to old, 04-18-2005 15:48:14
Randy, I am with Old, lack of fuel or Champion spark plugs.(I like Autolites or AC)
Don L C
04-18-2005 19:46:43
 Re: '52 Farmall Super C problems in reply to kjm, 04-18-2005 18:50:53
Sounds like its sucking air...start it ...squart W-D 40 around where the intake bolts to the head....see if you hear a change in the sound of the engine if so,need new gasket or re tighten only....check it could be a loos plug.
