Tractor Talk Discussion Forum
Farmall Super M
Mr V
06-21-2007 20:19:12
I have a Super M, and was told by the guy at the tractor shop that I could use IH hytrans fluid in the transmission. I was then told by another friend that I should use 80w90 gear oil. Could somebody help me out here? I don"t have a manual and have not owned an M for very long. If I can use hytrans I was thinking about using the whole rearend as my hydraulic reservoir for my loader. Anyway, if anybody knows I would appreciate your input.
sd pete
06-22-2007 09:50:47
 Re: Farmall Super M in reply to Mr V, 06-21-2007 20:19:12
I used hytran in a ol M that was a chore tractor in the winter. Didn't hurt it any
TDM
06-22-2007 05:58:42
You can use Hy-Tran with no problem, I've been using it for 3 years in my M. You do need good seals and you might hear more gear noise than if you were using 90 wt.
georgeky
06-22-2007 08:00:14
 Re: Farmall Super M in reply to TDM, 06-22-2007 05:58:42
With more gear noise comes more gear wear. Hy-Tran is not heavy enough for these old straight cut gears.
TDM
06-22-2007 09:44:05
 Re: Farmall Super M in reply to georgeky, 06-22-2007 08:00:14
Gear noise is a result of wear, go to your IH dealer and they'll tell you Hy-Tran is fine to run in the older tractors.
georgeky
06-22-2007 16:42:29
 Re: Farmall Super M in reply to TDM, 06-22-2007 09:44:05
I know what the IH dealer will tell you. I put Hy-Tran in my 200 several years ago on their recommendation and after plowing about 60 acres of tobacco I had to work on the rear end. The shop foreman there told me to put gear oil back in it as that was what GEAR OIL was for. IH dealers like to sell Hy-Tran.
buickanddeere
06-22-2007 17:32:30
 Re: Farmall Super M in reply to georgeky, 06-22-2007 16:42:29
Any gear set that doesn't involve hydraulics or wet clutch packs and doesn't use copper based bushings should use GL-5. Gear sets using copper based bushings are well protected with GL-4 Marine gear lube. Lets not forget how many wet clutch packs and wet brakes have been ruined by some genius pouring either GL-5 or the cheapest trans/hydraulic oil they could find. Didn't some of those M, Super M, 400 & 450's require TA,transmisison or final drive work even if the proper oil was used?
georgeky
06-21-2007 21:11:45
I missed the part about using it for a resivoir. You can do that. Either oil the Wisconsin Cowman suggested will probably work, but I would go with the 30 weight. Be sure that it is non-detergent. The old books recommend 90 weight in them.
Dean Barker
06-21-2007 21:10:40
These tractors all used 80W-90 or even 140 transmission oil.
I don't believe I would use hydraulic oil in the transmission in this tractor, unless you were using it exclusively in -30 degree weather.
georgeky
06-21-2007 21:05:57
That should have 90 weight in it. Along with any other that doesn't have a TA.
Wisconsin Cowman
06-21-2007 20:41:05
Use hytran or 30wt oil.
