Tractor Talk Discussion Forum
Changing Blades on a King Kutter Rotary Mower
lmcclue
04-24-2005 16:32:49
Anyone who has ever managed to replace the blades on King Kutter Rotary Mower...Help! Any tricks to pass on would be helpful. I've tried heating the bolt in the center to get it off, but I can't get any real pressure on it because the blades turn. I'm sure someone has a really easy way to deal with this, right? Thanks!
arkie
04-25-2005 04:21:02
 Re: Changing Blades on a King Kutter Rotary Mower in reply to lmcclue, 04-24-2005 16:32:49
i think you are trying to turn the bolts the wrong way, my kingcutter has left hand treads, on the blades, use a 2/4 or pc. wood wedge it between blade an cutter, on the end of the blade,use a felk handle,short pc pipe on end handle, good 6 point socket,once you get them off then you know, rest of the brands mentioned are just junk,
lmcclure
04-25-2005 06:24:34
 Re: Changing Blades on a King Kutter Rotary Mower in reply to arkie, 04-25-2005 04:21:02
Thanks everyone. I'll head out there today, and hopefully get it done.
TomTX
04-25-2005 02:11:11
Remove as stated in posts below. REPLACE with new bolts and nuts, now that you have heated them. You do not want to have even the slightest risk of losing a blade due to bolt breaking.
37 chief
04-24-2005 21:44:34
Next time buy a Woods mower. I can change the blades on my mower in under 10 min, with very little effort. I have a 6 ft cutter. I don't know why others don't have a better system for changing blades. stan
Robert in W. Mi.
04-25-2005 06:35:22
 Re: Changing Blades on a King Kutter Rotary Mower in reply to 37 chief, 04-24-2005 21:44:34
I agree, You get what you pay for.....
Allan in NE
04-25-2005 16:16:32
 Re: Changing Blades on a King Kutter Rotary Mower in reply to Robert in W. Mi., 04-25-2005 06:35:22
Chief, Robert,
I dunno 'bout that.
I compared the Woods vs the KK settin' side by side when I bought mine. That Woods outfit sure looks flimsy to me. Not nearly as heavy built as the KK Heavy duty model.
Allan
Jerry/MT
04-25-2005 20:22:59
 Re: Changing Blades on a King Kutter Rotary Mower in reply to Allan in NE, 04-25-2005 16:16:32
I agree with you, Allan. The comparison of the weights on the respective manufacturers web sites shows the KK to be about 50 lbs heavier than the Woods. I can't see paying twice as much for the kind of use I'll put my KK to.
Allan in NE
04-26-2005 03:55:09
 Re: Changing Blades on a King Kutter Rotary Mower in reply to Jerry/MT, 04-25-2005 20:22:59
Hi Jerry,
The one thing I did like about the Woods tho, was that they come equipped with the tire protector; all the KK has is the bolt holes for mounting one.
I'm thinking strongly about stringin' an old tire chain or a chunk of belting across the front of 'er just to be on the safe side. Dunno, all that spinnin' iron under there makes me nervous. :>)
Also, guess I didn't realize they were that heavy; gotta get me some weights on the front of that tractor to hold the front end down. Not used to mowin' while drivin' with the brakes. :>)
Allan
third party image
third party image
Jerry/MT
04-24-2005 20:54:09
I just got a new KK and my blade bolts have steel locktite on them(i.e. the nut/bolt end has a spot weld on it!). I reckon the "blue flame wrench" will be required to change the blades out. If yours are just torqued on than using a 3/4" drive socket and breaker bar and some penetrating oil should get you started. An impact wrench would probably help also. If you're worried about the blade carrier turning, leave the drive shaft attached to the PTO with the PTO engaged.(Engine off, of course.)The bolt is accessible from the top of the deck through the big hole behind the gearbox.
Nor. Al.
04-24-2005 18:42:53
clue I have a king cutter and there is about a 2"hole in the top across from the gear box ,you take a 1 1/8 " socket and stick on the nut and turn it , you don't have to hold it from the bottom as the bolt has a keyway that sticks to the flywheel or disk. You may need someone to lay down and hold bolt in place in the keyway until you get tap and lockwasher started .I like to use an angle grinder without taking the blades off.Good luck !
