Tractor Talk Discussion Forum
cub cadet 125
wayne scray
04-26-2005 13:21:40
how do i adjust the front power take off clutch that runs the lawn mower.
Red Dave
04-27-2005 07:21:04
 Re: cub cadet 125 in reply to wayne scray, 04-26-2005 13:21:40
Not sure what you want to adjust, but if it is slipping, I think you will have to take it off to work on it.
There are 6 allen screws (two to each hole) to remove it from the crankshaft. After it is off, you can increase the tension on the clutch disk by tightening the flat-headed screws that go through the clutch to the pressure plate.
I suggest you pick up a manual. There should be a description and a diagram in it that you would find very helpful. Try a Cub Cadet dealer or WWWBinderBooks dot com for manuals. (use all lower case)
