Tractor Talk Discussion Forum
need to find year of ford 701 (powermaster?) .
jimmy jim
04-27-2005 11:22:53
How do i find the year and horsepower of this tractor: ford 701 model 741 serial#5798 ? Gasoline, 4 speed, no live pto, row cropper?
Jim.UT
04-27-2005 16:04:39
 Re: need to find year of ford 701 (powermaster?) . in reply to jimmy jim, 04-27-2005 11:22:53
The 701 series was called a Workmaster (as was the 601 series). It came with either a 134 cu inch gas engine or 144 cu inch diesel. The 701 came either as a 741 (4 speed) or 771 (Select-O-Speed).
The earlier version of that tractor was a 700 series and came only as a 740, 4 speed and only with a gas engine. Horsepower on the smaller engine is about 32.
Visually, you can identify a 700 from a 701 by color if the paint hasn't been messed with. A 700 will be gray sheetmetal and red castings. A 701 will be all red except for gray grille, wheels and fenders.
Here's a site to help out on location of serial number and model number. There may be date codes on various parts of the tractor that will help corroborate what the serial number tells you.
Also, the 700 and 701 series (as well as the larger 900 and 901) came mostly with a narrow front end. However a wide front was optional and there were aftermarket wide front conversions available.
Steve (Magnolia, TX)
04-27-2005 12:18:41
Look down and to the left (No!! your OTHER left :-) ) for the Serial Numbers link.
Under Ford, 501,601,701,801,901 you'll find starting serial number for each year of production.
5798 would've been a 1957 model.
HTH
Steve
tlak
04-27-2005 12:31:32
 Re: need to find year of ford 701 (powermaster?) . in reply to Steve (Magnolia, TX), 04-27-2005 12:18:41
Year Starting Serial Number 1954 1 1955 10615 1956 77271 1957 116368 Those sn's are a little hard to go by. The 700 series makes it a 1955. The other site which I don't have the link breaks it down better.
tlak
04-27-2005 13:27:19
 Re: need to find year of ford 701 (powermaster?) . in reply to tlak, 04-27-2005 12:31:32
I identified it for him then didn't even catch the 01 thing. Oh well.
04-27-2005 12:38:09
You're looking at 700 numbers.
Go to the 701 link...
1957 1001 1958 11977 1959 58312 1960 105943 1961 131427 1962 155531
Steve
old
04-27-2005 11:34:10
HP is some where around 40 give or take a little
