Tractor Talk Discussion Forum
craftsman 18hp twin II
cuffem
05-01-2005 19:58:30
THE TRACTOR WILL START WITH CHOKE OUT AND WHEN YOU PUSH THE CHOKE IN . IT ACTS LIKE ITS RUNNING OUT GAS. NEW PLUGS , FUEL PUMP AND FILTER
MikeinKCMO
05-02-2005 04:17:56
 Re: craftsman 18hp twin II in reply to cuffem, 05-01-2005 19:58:30
Another vote for gas probs. Should get a good stream of gas at the carb from the fuel line. If thats OK then the carb is dirty. Disassemble clean, blow out every little hole you see with compressed air. Reassemble. Get the lawn mowed.
baler46
05-02-2005 03:40:55
Hi This spring i had a ranch king that did the same thing ,gas line was bad sucking air.Put new gas kine hose ran great again.
Ryan -WI
05-01-2005 20:05:01
How old is the gas? Did you check to make sure both plugs are tight?
bo
05-01-2005 20:04:41
Carb is gunked up...needs to be dissasembled and cleaned.
UncleTom
05-02-2005 02:59:24
 Re: craftsman 18hp twin II in reply to bo, 05-01-2005 20:04:41
Sounds like it is starving from fuel for one reason or another. Filter, fuel line, nedle and seat, or main jet. Just my .02
mine does the same thing.
05-02-2005 05:40:57
 Re: craftsman 18hp twin II in reply to UncleTom, 05-02-2005 02:59:24
I have the same problem on mine every year....your carb is dirty.....drain the float bowl.....take out the 4 torks screws on top of the carb and remove the top.....this has the float and needle and seat.....spray the inside of the carb with carb cleaner..... blow all the little holes out good....spray the float and the needle and seat.....
that should take care of the problem.....
