Tractor Talk Discussion Forum
IH B275 diesel
Munkle
05-03-2005 16:46:33
Hello there,
I have a B275 that will not start. I have replaced the positive cable to the solenoid and negative to the starter. I have ohm'd the positve cable to the starter and I know that it is good. I removed the starter and bench tested it to see if it would turn. When I put power to it, I got roughly 150-200 rpm out of it at first and then within 2-4 seconds later it would die to roughly 50-90 rpm. I used a power source that supplies consist power. (I didn't want to wonder if the battery I was using was going bad).
Is this normal? I am thinking that the starter is shot. What do you all think?
Thank you,
Munkle
jdemaris
05-03-2005 19:34:52
 Re: IH B275 diesel in reply to Munkle, 05-03-2005 16:46:33
It's ten minutes work to pull the starter apart and take a look inside. If the brushes, armature, brush holders, etc. are bad or stuck, you'll see it. Same goes for the solenoid.
