Tractor Talk Discussion Forum
4020 clutch job/PTO actuator
Kraig
05-03-2005 19:23:13
I have a 4020 split and was wondering if there was any need to touch the PTO actuator. As far as I can see it is not leaking, although the whole bell housing is oily from the crank seal going. Is there anything routinely done to the actuator seeing how the tractor is apart or should I just leave it alone? Thanks.
jdemaris
05-03-2005 19:31:24
 Re: 4020 clutch job/PTO actuator in reply to Kraig, 05-03-2005 19:23:13
You didn't specify which actuator or transmission you have. I assume you have a SynchroRange and not a Powershift. The early 4020s with SynchroRange have a mechancial engagement system, and the later have hydraulic. If you have the early system, don't worry about it. If you have the later, at least replace the o-rings and back-up washers - and check the pistons for scoring. Also -this is kind of a "no-brainer", but replace the PTO engagement bearing and make sure the clutch fingers aren't getting worn at the tips.
